While the SET 400 might not be the optimal choice I don't think its a bad one.
In the meantime, just ordered a SET 400.
From my post above: "Will be used with a refurbished Yamaha C4 pre-amp for now, but eventually want to move to a tube-based pre...Sources are Marantz TT15 turntable and FLAC > Schitt MODI 3 DAC. (Mostly vinyl.) I don't necessarily listen at high volumes very much, but system is set up in a largish 'great' room."I do understand that the Modi is pretty much a bottom of the line DAC. It'll get upgraded at some point. As you note, "money money"...
Outsider, your SET 400 shipped to you today via insured UPS.Thanks much for your order.Let us know what you think after enjoying it for a few days.Frank
Ouch!https://www.ukaudiomart.com/details/649424817-preamplifier-yamaha-c4/images/1832235/https://www.hifiengine.com/manual_library/yamaha/c-4.shtml (1979-1981)
Maty, He said it was refurbished so all those old capacitors and such that repel you so much, should all be gone.It's a great looking pre. Just wait first before even thinking about a new one.
The only problem- and one familiar to many here I bet- is that the SET 400 will probably outclass my pre-amp and sources by a fair margin, indicating I should probably also upgrade those as funds allow..
