Depends. In some cases, agree. However, there are exceptions to this. Some amps have sufficient engineering where bridging with low(er) impedance speakers is not an issue.
McIntosh amps with autoformer output.
Hello, Freo-1.I looked into Devialet a while back after you mentioned them to me. Their SAM technology does sound very attractive. However, in my case, Devialet has not added Daedalus speakers, Jeff Bagby speakers, nor Fritz Speakers to their list, so I cannot take advantage of that bonus. Michael
Regarding bridging amps, as long as the speaker doesn't go much below 4 ohms for a large part of the frequency spectrum, the extra power is welcome.
There are a lot of bridgeable amps that don't like a load much below 8 ohms since the bridged amp sees an 8 ohm load as 4 ohms and a 4 ohm load as 2 ohms. Better off using them as a 2 ch amp with 4 ohm speakers; no extra power in these situations.
Agreed. I'm getting my first set of monoblock amps fairly soon, two Hypex NC1200s. It's remarkable what's happening with Class D amps. A few years ago, NC1200 amps cost as much as a small car. Now they can be had for about $1000 per monoblock. While these types of Class D amps can't be bridged, they are putting 400W into 8 ohms and 700W into 4 ohms. So that's a bit.
