BDA-3.14 volume control
0 Members and 1 Guest are viewing this topic. Read 3840 times.
WildPhydeaux
Re: BDA-3.14 volume control
« Reply #20 on: 11 Jul 2020, 09:00 pm »
I prefer analog control myself as I listen to DSD.
Now someone said getting a remote with a BDA-3 does not then use digital volume control. If that were case I would buy a Bryston remote in a heartbeat...
I prefer to use an analog volume control no matter what the source is. All digital volume controls are data lossy - leave then at 0db and use a proper preamp, but to each his own.
I believe the person that said whatever they said about the remote was likely unclear in how they stated it would not use the digital volume control, although I'm speculating. I suspect if you have that remote it can control the volume on a Bryston preamp, therefore analog volume control. If not, then they are simply incorrect because there is no other way to control the volume output of a BDA3 than digital.
Robert
dirk
« Reply #21 on: 13 Jul 2020, 02:22 pm »
Hi Sasha
i would say another month or so.  yes it will have the Pi4
james
Hi James,
Will it replace the bp17(3) ?
Or will the bp17 be still for sale ?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #22 on: 13 Jul 2020, 03:03 pm »
Hi James,
Hi,
No it will not replace the BP17 or the BP26 preamps.
They will stay in the line as they have different feature sets and prices.
james
Sasha
« Reply #23 on: 26 Jul 2020, 11:06 pm »
Hi James,
Are there any news on BP18, how is it coming along?
Sasha
« Reply #24 on: 27 Jul 2020, 12:16 am »
Hi James,
Sasha
Hi Sasha
Yes I had the prototype home last week and did some blind testing.
I would say we are about 3 to 4 weeks away from the final version assuming all goes well on the software side.
james
GeAllan70
« Reply #25 on: 27 Jul 2020, 02:05 pm »
any spy photo's??   :lol:
Sasha
« Reply #26 on: 27 Jul 2020, 02:57 pm »
Hi Sasha
james
Hi James,
If you need a prototype tester I am more than willing :)
Sasha
