thanks guys for the info. I wish their entry was a bit cheaper. Our Canuck buck is yuk right now. Can't imagine they come up used that often. Then I would have to get a new amp and pre to match. Good lord I must stop dreaming.
WGH i disagree that ME1’s plus a REL Gibraltar subwoofer could equal any $100,000 system. It may well come close or rival it in one aspect or another, but not in all aspects. You are basically saying an ME1 plus REL Gibraltar would equal TAD Reference One which is around the $100,000, not a chance.
Only heard TAD at shows over the years and was not always as impressed as I had hoped to be given the reviews, but isn't that usually the case at such demos. I suspect set-up is the problem in hotels, some rooms are better than others obviously. In recent years I've started to appreciate the fit of monitors/sub over floor standers in many situations, they're just not as a impressive to look at . I think the last time I heard the ME-1s I was quite taken by them but I can not recall the partnering equipment or if a sub was involved.
thanks all ,, Pioneer ? Really ? The old add for the S1-EX shows 9000.00 way back then. Do they still make these ? Interesting.
Try TomS, he owned a pair for years.
