Couple of Questions About the DAC DAC
0 Members and 1 Guest are viewing this topic. Read 2085 times.
BruceSB
« on: 1 Jun 2020, 04:33 am »
Hi
Couple of questions about the DAC DAC.
Noticed it is to be fed by a 12 volt DC supply,
But, no mention of how many amps it requires.
Thinking it may be 12 volt, 2 amps but that is just a pure guess.
How many amps is it?
Assume that, ideally it should be fed from a linear power supply.
Can you supply one?
Did not see it on the site.
Or, maybe you could recommend some suitable linear power supply units.
Keep up the good work.
You make some great stuff.
Look after yourself.
Bruce
AmpDesigner333
  • Detailed AND Musical
    • Digital Amplifier Company
Re: Couple of Questions About the DAC DAC
« Reply #1 on: 2 Jun 2020, 01:30 am »
Hi
Can you supply one?
Bruce
Bruce,
500mA (6W) is more than enough for the Cherry DAC DAC.
We’ve tested with injected power supply noise (and various power supplies) and have found no difference in performance. Let me explain why this is the case....
Power enters the DAC (regulated 12VDC in the case of the small stock supply) and is reconstructed in several steps. The analog supplies are then re-regulated for ultra low noise.  The digital supplies are filtered and decoupled at the destination.  The idea is to make a device immune to power supply noise.
Thanks for the complements (:
BruceSB
« Reply #2 on: 3 Jun 2020, 12:10 am »
Thanks.
Love the way that you always come back and answer questions in such a nice way.
Bruce
