0 Members and 1 Guest are viewing this topic. Read 12989 times.
For a Solid State DAC I've settled on the Aqua La Voce S3 for the last year. If I get the urge for the tube sound I swap in the Musical Paradise MP-D2 Mk III Deluxe.
LarryThe Musical Paradise is not better just a different flavor as is the Directstream Sr. which hasn't been used for a while. Sometimes I just swap them out for a change. My Aqua started out as an S2 but I sent it back for the upgrade last year after the Munich show. Took quite a while to break back in as a majority of the guts were swapped out. I can imagine some buyers giving up before the break-in was complete. I just put it in a spare room with an old Oppo and a test disc on repeat for a couple of weeks.
The Aqua is a great sounding DAC. I doubt that the Paradise would sound any better but you won't know until you try. The S3 is on my radar. I would love to hear how it sounds compared to my Luxman DA-06.I would not put much stock in $1K DAC's sounding better than $10k DAC's. I have owned quite a few high end DAC's in the $3K to $6K range and none of the lower priced DAC's sounded as good as the more expensive ones. I have also heard a few other DAC's of friends and we did DAC shootouts. In just about every instance the more expensive DAC's sounded better. The biggest differences are width, depth and height of sound stage and especially the separation between instruments. You get what you pay for. But I certainly agree that the gap has closed some. I also have found that some systems like mine are very sensitive to changes in DAC's. DAC's are definitely system dependent.
I'm really enjoying my new Bricasti M3 with network board, no more USB cables and dongles just Ethernet only to a network. Big improvement over the Comet and at twice the price expected.
I must admit to spending precious little time reading about La Scala DACS. Can you talk a little more about the S2/S3 versions, and how does the Optologic DAC differ from them? I've never heard any of these models.
LarryYou might want to see if you can get a demo of this DAC from Boris. Built down the road from you in Eden Prairie. Joe on AS has one and loves it.https://www.audiomirror.com/product-page/tubadour-iii-se-nonoversampling-tube-dac-2500
So AD1865 better than the Phillips TDA1541?
Also someone online who has the ANk to 2.1 sig dac says the stock AN Dac 0.1x was better! Have you heard this?
