Advice on which adhesive to use, to re-glue speaker grill cloth peeling (pics)
0 Members and 1 Guest are viewing this topic. Read 1358 times.
AverageNiceGuy
I'm looking on advice on which adhesive will work well to re-glue speaker grill cloth that is peeling off edges? (photo's)
Perhaps I should do something to re-secure the cloth that is not yet peeled up?
Most of the stuff that comes to mind currently will probably look bad.
Advice?
Peter J
  • Hmmmm
This may  work, although I haven't used it being a stapler kind of guy.
Is it fabric or foam?
https://www.simplyspeakers.com/speaker-grill-cloth-repair-adhesive-mi-3035.html
AverageNiceGuy
Thanks.
That will probably work.
It is fabric.
AverageNiceGuy
Ordered,
Thanks again
