X-LS ENCORE
0 Members and 1 Guest are viewing this topic. Read 975 times.
mmurt
X-LS ENCORE
« on: 23 May 2020, 09:44 pm »
I ordered the kit for these and because they are going to be sitting on a bookshelf we think a sealed version is better.  My question is do I build these with the rear port then plug the port or a sealed back panel?  If plug, what material do I use?  Thanks, Mike
roscoe65
Re: X-LS ENCORE
« Reply #1 on: 23 May 2020, 09:54 pm »
Build the ported version and stuff with a foam ball.  Or a rolled up sock.
mlundy57
Re: X-LS ENCORE
« Reply #3 on: 24 May 2020, 03:47 pm »
I'd build it with the port and plug it if the bass is too boomy. That way, if you move them to another location in the future where they are farther away from a wall, you can unplug the ports.
mmurt
Re: X-LS ENCORE
« Reply #4 on: 24 May 2020, 04:48 pm »
Great, Thanks guys!
