0 Members and 1 Guest are viewing this topic. Read 8712 times.
Mozel Tov!Are you accepting visitors into the shop? I'd like to stop by Glenn
I would be interested in trying the Gaia footers on my 9.5. Can you tell me how the stock cones are threaded?Thanks!
Jim, can you provide an update on these speakers? How would you compare the Seas diamond tweeter to the SB Acoustics Beryllium and to the Raal ribbon tweeter? Thanks for your input!
Sorry for the delayed response. We've been quite busy here lately trying to recover from lost covid time.This is a difficult question to answer.The diamond tweeters are about as close to "no tweeter" I have heard. They are very open, detailed and transparent. If you close your eyes, you can almost reach out and touch the performers.That said, you could almost say the same thing about the Be and RAAL tweeters as well.I think the differences are incremental. And all three are fabulous drivers. If you have low ceilings and/or hard flooring, the RAAL might be more applicable since less energy is directed above and below the tweeter (more limited vertical dispersion). Off-axis response may be a bit better with the Be and diamond tweeters, but not by much.The bottom line is that you can't really go wrong with any of these tweeters. Each is probably the best in its category. I would gladly use any one of them without a second thought.I hope this helps.- Jim
Sorry to resurrect an old thread, but I was hoping Jim or any board member could comment on the use of Gaia footers. I saw they were added to this go-for broke construction.. are they worth the incremental investment beyond traditional floor spikes? All feedback is appreciated!
Herbies Audio Lab spike decoupling gliders provided the flexibility I was looking for. They may not be as aesthetically pleasing as the Gaia footers. But, they fit well with the spikes that came with the SS8s. They provide exceptional ease of movement/placement.
The Gaia footer looks great and works well. But when moving a speaker with them installed, one of them came apart. So the comment about moving them may be accurate. I don't know if the footer was defective or that you have to be really careful moving speakers with them installed.- Jim
A quick easy fix for moving these on hardwood floors especially as I do, spray some Pledge wax on the area and they will slide very easily.
