Amber 3 USB Connected to Innuos Zenith MKIII Server
0 Members and 1 Guest are viewing this topic. Read 2833 times.
fado
« on: 18 May 2020, 03:36 pm »
I just got an Innuos Zenith MKIII and it will automatically find a connected DAC when only one DAC is connected to it. With the Amber 3 connected it shows: "JLsounds JLsounds Hi-Rez Audio 2.0" and will not change when I refresh the DAC selection. It does not show Lampizator or Amber 3.
Does the Amber 3 with the newest USB interface use JLsounds JLsounds Hi-Rez Audio 2.0?
Gopher
Re: Amber 3 USB Connected to Innuos Zenith MKIII Server
« Reply #1 on: 18 May 2020, 06:30 pm »
Yes.  Jlsound is the USB module.
Please select that.
fado
« Reply #2 on: 18 May 2020, 08:08 pm »
Thanks - that worked.
