0 Members and 1 Guest are viewing this topic. Read 17665 times.
I have a Pass X250 amp and it gets hot.
Yeah. Heat depends on class A bias which varies by model. I had the XA 30.8 for about a year. It ran hot enough to heat up my listening area by a couple of degrees. It ran MUCH warmer than the 30.5 I once had. It didn't run so hot I couldn't put my hand on it. I would say the heat it contributed was similar to that of having another person or perhaps a somewhat large dog in the room with me. The .8 series runs deeper into high bias class A than the .5 series. Note the 260.8's are monoblocks, which would certainly increase room temps.
RD, the XA series is Class A not A/B, so that explains the increased heat issues. Interesting that it's warmer than you're 30.5 ? Of note with the .8 series (A/B) the X260.8 mono blocks have the highest amount of initial Class A bias, save the mighty '650'. My 260.8's will heat up my room (14'6"x24') by a couple of degrees.Also of note , a Class A circuit at idle will produce more 'heat' since it is always 'on'
IThat DAC Stereo Maraschino sure seems like a winner... very tempting!!!
For background music, NAD good enough.
I want to thank everyone for taking the time to give me some suggestions.. a lot of really interesting options here I hadn't considered, or heard of in some cases! I'm glad I asked!That DAC Stereo Maraschino sure seems like a winner... very tempting!!!
