Review: Fritz Heiler’s Carbon 7 SE Mk 2 Bookshelf Speakers
0 Members and 2 Guests are viewing this topic. Read 9540 times.
hilde45
5/13/20 by hilde45
I’m happy to post a review of John “Fritz” Heiler’s wonderful Carbon 7 SE Mk 2 bookshelf speaker. After we corresponded a bit over email, Fritz suggested I try out his speakers and, if I felt inclined, to write something up about them. I do not own them and will be sending them back to Fritz whenever he calls for them. I am not in the audio industry in any way, shape, or form. I’m a college professor and a relative newcomer to high quality audio, though I have been interested and have owned some decent mid-fi gear since the 1980’s.
After spending over a month with them doing a lot of listening, I’m happy to convey my impressions of these speakers. I offer them with apologies in advance: I’m a careful listener and love music; what follows represents my best effort to capture what I heard.
This review ran a bit long, so here are the sections covered.
SETUP
Design
Burn-in and Equipment
Music Sources
Setup/Listening position
LISTENING
Complex Passages
Soundstage
Dynamics
Bass
Midrange
Treble
Comparisons
CONCLUSION AND NOTES
Design
As relayed on his website, the Carbons are a 2-way vented stand mounted monitor; they have a frequency response of 38Hz - 35Khz +/- 3 db, an impedance of 8 Ohms nominal @ 1000 kHz, and a sensitivity of 88 db. Drivers include, first, a 7" Carbon Graphite Fiber/Paper Pulp composite cone with non-resonant low loss butyl rubber surround & Kapton voice coil former & die cast frame with massive magnet, bass reflex loaded rear port. Second, they use a 1" ScanSpeak Textile Diaphragm wide surround Dome tweeter. There are Acoustic Reality Series Crossovers without any capacitors or resistors in the circuit with the tweeter.
The speakers are hefty but not unwieldy. Their dimensions/weight are 16H x 9W x 12D, 32 lbs (each). The recommended power is 30 - 150 Watts RMS, without clipping. More details, including very attractive choices of wood grains, can be found on Fritz’s website.
Burn in: Fritz told me the speakers had some hours on them but hadn’t been used in a while. I played them for about 50 hours before doing critical listening. My associated equipment had 50-100 hours of burn in.
Equipment used was as follows. Amplification came from a Quicksilver Line Stage (non-remote version) and a Quicksilver Mono 60’s (60 wpc) amplifier. Tubes were stock (12AT7 in preamp; 12AX7B input, 12BH7A driver, JJ KT 88 output). Source components were the Cambridge CXC transport and a Bluesound Node 2i streamer both fed into an MHDT Orchid DAC. Cables included a Toslink for CD, Analysis Plus Crystal Solo coaxial for streamer; RCA interconnects were Analysis Plus Copper Oval; power cords were Pangea AC 14SE MkII for everything but the CD transport and the QS mono blocks, which used Pangea AC 9SE MkII. Speaker Wire was Analysis Plus Oval 12 speaker cables. Power conditioning was by a Panamax 1500.
Music was served up in CD quality and high resolution files from the CD player, Amazon Music HD, and Qobuz.
The room is a basement rectangle with a small hallway lead in. It has concrete floors with thin wall-to-wall carpeting and a Turkish rug in front of a couch. Main listening area dimensions are 27’ x 14’ and the ceilings are 6’5” high. Total listening area is about 400 square feet. As far as I can measure, there are no first reflection points close enough to interfere with the initial sound from the speakers.
After some experiments with placement, I set the speakers 3’ 3” from the long wall (made of brick), about 11 feet apart from one another, slightly toed in, and about 9 feet to my listening position on a couch (tweeter to ear). The speakers sat upon sturdy MDF stands about 25” high. Behind the listening position and lining the entire opposite long wall are bookshelves, floor to ceiling, filled with an irregular array of books.
LISTENING
Complex Passages
Handling complex passages means presenting complex and intertwining melodies and sonorities without muddling them into the sonic equivalent of tangled cords. In Ives’ “Overture & March 1776” the soundstage was spacious enough to present a jarring cacophony in a way that was still musical; the space was big — a snare drum tapped far in the distance while various horns and other percussion were more immediate, albeit spread across the field. Steely Dan’s lusher pieces (e.g. “Black Cow”) contain many more instruments and singers than I realized because the Carbons gave them sufficient separation.
Soundstage
One of the reasons I ventured into an all-tube system was to experience what people kept referring to as “holographic” sound stages. And while I’ve never owned electrostatic or panel speakers, I had the expectation that a good pair of speakers should be able to recreate wide, deep, and tall arrangements of live music. Placement experiments with the Carbons paid off, and I was treated to a variety of engaging and effective sound stage experiences.
As I mentioned above, Ives’ “Overture” spread a rowdy orchestra before me, presenting a serendipitous and dissonant geography; Brian Eno’s Apollo (“Under Stars,” “Matta,” “Secret Place”) depicted vast textured spaces occasioning tiny events. David Chesky’s “General Image And Resolution Test” from The Best Of Chesky Jazz And More Audiophile Tests Volume 2 provided an opportunity to hear the Carbons produce sounds both to the side and behind my listening seat.
The soundstage produced also expresses smaller performance venues and places individual performers precisely. In Nordic Sound’s Vivaldi recording, “Recitative And Aria,” the string section was clearly localized, as was the soprano, her singing emerging from an atmospheric halo. Jazz duo Towner/Peacock’s bass and guitar strummed right before me; Towner’s fretting was just the right distance from his strums, plucks, and hits. Helen Merrill’s live disc You and the Night and the Music (“You and the Night and the Music,” and “I want to be Happy”) put me in a small jazz club. Keith Jarrett’s trio (Whisper Not, “Poinciana”) opened up into a much larger space; piano, bass, and drums were spread naturally across the listening field, and DeJohnette’s various drums appeared as distinct shapes in space. On that cut, the audience’s applause is dimensioned and articulate — I heard many individuals clapping rather than just a crowd.
Dynamics
Because I’ve spent so much of my life listening to compressed music, it’s been a great experience to listen to high resolution and audiophile recordings. The Carbons were up to the task of tracking big dynamic shifts; among the biggest, Ives’ “Overture” swelled from a whisper to a thunderclap so quickly that I nearly jumped off the couch. Carlos Kleiber’s crisp, dramatic opening to Beethoven’s 7th Symphony moved between sudden and subtle. On Lou Reed’s “Take a Walk on the Wild Side,” the creepy approach of the background vocalists reminded me of the first time that song messed with my head, 40 years ago.
Bass
Because I grew up listening to Acoustic Research three-way AR 48s, which have 10” woofers, I was used to mains that could reproduce bass really well. The Carbon’s woofers are not that large, but their bass response is excellent — deep and accurate. Some recordings — such as Donald Fagen’s “Morph the Cat,” or the Towner/Peacock duo’s “Opalesque,” — surprised me with their bass extension. On “Morph,” bass was quick, effortless, controlled; drums had kick and power. On Jennifer Warnes’ “The Ballad of the Runaway Horse,” Rob Wasserman’s bass provided a detailed, rich, woody, heartbeat that propelled the folk tale forward. The Carbon’s conveyed Eno’s Apollo bass impressionistically by creating a fathomless, spatial arena. On all these tunes, the Carbons did all I could have asked for, and it was only when I turned on my REL 328 subwoofer did I realize that there was a bottom end which could be filled a bit further. Still, it was easy to listen without the sub, and I often forgot that I had it.
Midrange
I’m not alone in wanting instruments to sound like themselves, and one strength to the Carbons is their honesty. Across the variety of music I played, I never wondered what I was listening to (with the exception, perhaps, of Brian Eno!). For example, Ives’ “Overture & March 1776” parades a huge variety of instruments at different distances, both clashing and in unison. I never mixed up a piccolo with a flute or a bass clarinet with a contrabassoon; various percussion instruments (snare drum, tam-tam, triangle, celesta) all played unique role in Ives’ patriotic pileup.
Male vocals were also good tests for the Carbon’s lower midrange. Jazz vocalist Gregory Porter’s sumptuous baritone materialized before me with confidence in “No Love Dying” . His “Lonesome Lover” used a very gentle reverb on his voice which came through nicely; horns were crisp and separated, as were different elements of the drum kit. Fagen’s lead vocal on “H Gang” is double tracked, and the speakers clearly articulated the clever mix which leaves just a bit of space between their not-quite-identical sonorities. Nordic Sound’s recording of “Gregorian Chant” by Crux Fidelis & Consortium Vocale filled the room with a cohort of individual voices.
Female vocals were especially well drawn; I was already a Jennifer Warnes fan and only later realized that she’s on most audiophile playlists. The Carbons capture her expressive and wide-ranging style in “Lights of Louisiana” and “The Ballad of the Runaway Horse”; her breathy sibilance was lush, but not overdone.
One final word about piano and the Carbons. Second only to guitar, piano is a favorite of mine. The ability of the Carbons to handle it across jazz and classical were crucial to me, and the Carbons did extremely well. Jarrett’s lines (“Poinciana”) were delightfully liquid, Gould’s stereo re-do of the Goldberg Variations (much more dynamic and percussive than his 1955 mono version) was startling and the piano had a personality.
Treble
Sticking with piano as a test of a speaker’s treble response, I listened carefully to passages played in the upper octaves. The Carbons performed nimbly; Jarrett’s “Poinciana” had upper notes which trickled and sparkled but with body — never brittle. (This was true both with an all-tube setup and, on an earlier occasion, via my solid state Adcom gear playing through an older non-tube Peachtree DAC-IT.)
Cymbals tested well, also. In “Poinciana” and Steely Dan’s “Babylon Sisters,” ride and splash cymbals had a friendly, musical, metallic ring that didn’t decay too quickly. Snares had a healthy kick. Towner’s picking and percussive scratching on his nylon string guitar (“Creeper,” “Postcard to Salta, “Amber Captive”) were all expressed by the Carbons.
Comparisons
Because I’ve been shopping intensively for bookshelf speakers in the last few months, the Carbons came at a time when I had a lot of other speakers on my mind. I don’t want to drag out what is already a long review, but there are a few things to say immediately in comparison.
First of all, the Carbons are better (based on what I heard — caveat: outside my home) in tonal balance and imaging than Focal Aria 906, B&W 707, and the GoldenEar Aon 3. None of these speakers are in Fritz’s price class (they’re about $1000 lower) but all have gotten a lot of good press, so it’s worth mentioning that the Carbons blow these away — better bass, more natural and full vocals, and treble that is equally detailed but not too fatiguing. In character, to my ear, Carbons are more akin to the Dynaudio Evoke (especially the Evoke 20) line and a couple of the Totem models (e.g. the Sky and Skylight). I enjoyed all of these speakers, but liked the Carbons more. I also would put the Carbons above of Spendor’s floor standers, including the A4 (about $1000 above the Carbons).
The other speaker I own, purchased to bide some time in quarantine, is the new Klipsch RP-600M. This speaker is 1/4th the price of the Carbons (and weigh half as much). When I first listened to these speakers (after some burn in), they seemed quite different in character but equal in quality to the Carbons. The Klipsches separate instruments very well and the upper mids and highs are super crisp. Their sound stage is quite wide.
Five weeks later, I realized that there is absolutely no comparison. The Klipsch are completely outmatched by the Carbons — in comparison, they are a bit etched in upper mids and highs, their soundstage is wide but less articulate, their bass is quite present but less woody and organic. They have the potential to fatigue me to the point of reaching for the off button. Also, voices are somewhat less warm, human. With the Carbons, I never wanted to shut them off. While Klipsch’s sound ok, the Carbons helped me distinguish between, let’s say, the “Mercedes level” of a speaker vs. the “Toyota Corolla level” of the Klipsch. (With all due respect to the YouTube reviewers who fall over themselves for the Klipsch.)
Conclusion
As this review hopefully demonstrated, these speakers are outstanding performers, beautifully built, and made with care and quality. They’re the product of Fritz’s long-earned expertise and attunement to what the music wants. Because Fritz sells directly, they represent an exceptional value. I heartily and unreservedly recommend these speakers to anyone looking for a bookshelf monitor.
END
Notes:
Please find below a list of the recordings mentioned in the review.
JAZZ
Gregory Porter, Liquid Spirit (high res): “No Love Dying,” “Lonesome Lover.”
Keith Jarrett Trio, Whisper Not (live): “Poinciana” (CD)
Helen Merrill, You and the Night and the Music, “You and the Night and the Music,” and “I Want to be Happy”
Ralph Towner and Gary Peacock, A Closer View (CD): “Opalesque,” “Creeper,” “Postcard to Salta, “Amber Captive.”
ROCK/POP
Lou Reed, Transformer (remastered, high res) “Walk on the Wild Side”
Steely Dan, Gaucho (remastered, high res), “Babylon Sisters”
Donald Fagen — Morph the Cat (high res.); “Morph the Cat, “H Gang”
Jennifer Warnes, Famous Blue Raincoat: 20th Anniversary Edition (Digitally Remastered; high res.): “Ballad of the Runaway Horse.”
Jennifer Warnes, The Hunter: “Lights of Louisianne.”
OTHER
Brian Eno, Apollo (remastered; CD): "Under Stars,” "The Secret Place,“ “Matta”
David Chesky, Stereo Review & Chesky Records: Gold Stereo And Surround Sound Set-Up Disc, “General Image And Resolution Test From The Best Of Chesky Jazz And More Audiophile Tests Volume 2.”
CLASSICAL
The Nordic Sound 2L Audiophile Reference Recordings (high resolution)
* Gregorian Chant - Crux Fidelis & Consortium Vocale
* Ives: “Overture & March 1776” by Kristiansand Blåseensemble
* Vivaldi: Recitative And Aria From Cantata Rv 679, Che Giova Il Sospirar, Povero Core by Tone Wik & Barokkanerne
Beethoven: Symphonies Nos. 5 & 7 Reissued, Carlos Kleiber (Conductor), Wiener Philharmoniker (Orchestra) Deutsche Grammophon, 1996.
Glenn Gould, The Goldberg Variations, Sony, 1981
N.B. I also posted this review at the Audiogon, where I am also a participant. If this kind of cross-posting is forbidden, please let me know. I did this on my own initiative.
« Last Edit: 15 May 2020, 11:08 am by hilde45 »
Re: Review: Fritz Heiler’s Carbon 7 SE Mk 2 Bookshelf Speakers
« Reply #1 on: 14 May 2020, 10:21 pm »
Thanks for the detailed review hilde, well written.  :thumb:
timind
  • permanent vacation
« Reply #2 on: 14 May 2020, 11:02 pm »
Excellent review. I've read a lot about the Fritz speakers, but have never seen/heard a pair. I hope I get a chance sometime. Thanks for posting this.
hilde45
« Reply #3 on: 14 May 2020, 11:16 pm »
Thank you for your kind words! A pleasure to review.
« Last Edit: 15 May 2020, 01:30 am by hilde45 »
jonbee
« Reply #4 on: 15 May 2020, 12:36 am »
I'm not surprised that they are excellent. Frirz know what he is doing, with excellent parts and build quality. He employs series crossovers, which are unusual and to my ears usually offer a very seamless blend. Very cool.
MikeInAustin
« Reply #5 on: 15 May 2020, 12:50 am »
What a treat.  That required an extensive commitment to compile.  Thank you.
I spoke to Fritz about three weeks ago about building me a pair of speakers.  Sent him details of my room and components.  So excited about what is to come.
JackD
« Reply #6 on: 15 May 2020, 01:49 am »
Great job Hilde, I feel the same way about my Carrera Be's.  Would love to hear one of the other models some time with the Scan Speak tweeters.
hilde45
« Reply #7 on: 15 May 2020, 12:46 pm »
I'd love to hear the Carrera Be's. Nice write up, here: https://forum.audiogon.com/discussions/fritz-carrera-be-review-link
jtcf
« Reply #8 on: 15 May 2020, 06:30 pm »
Very nice review.One thing that stands out that I really appreciate is how you carefully explain your comparisons to other speakers.Your gear is similar to mine which captures my interest even more.One question I have is how are they with not so great recordings?
hilde45
« Reply #9 on: 15 May 2020, 07:04 pm »
Thanks jtcf — glad you liked it. Comparisons are tricky because when room or amps or multiple factors vary, it's really not fair to judge. I'm sure there are folks out there who love some of the speakers I didn't prefer, so hard to say.
To answer your question, with not-so-great recordings, they did reveal the lower level of quality but not as painfully as the Klipsch. For example, I listened to an old Joe Jackson album, Look Sharp, and compared the older vs. remastered versions; night and day. Some other old favorites which also suffered included some Joni Mitchell and some David Bowie; I was certain Bowie would sound great, but not so much. On the other hand, some older Jethro Tull sounded amazing, as did some Fleetwood Mac.
If I listened to a lot of older recordings and it bugged me, I might get a Schiit Loki or other equalizer.
Wind Chaser
« Reply #10 on: 15 May 2020, 09:13 pm »
Thanks for writing this thoughtful commentary, you have kindled my interest in the Fritz line.  :D
hilde45
« Reply #11 on: 15 May 2020, 11:42 pm »
I'm so glad. There are so many brands out there, it gets very confusing. I'm no expert about the vast array of products, but what we seem to have here is an artisan, experienced, selling direct, with a trial period, and high quality sound.
« Reply #12 on: 16 May 2020, 02:51 pm »
Thanks for the review and plug for Fritz.  Met him at a show 11 years ago, very personable, and heard his speakers.  They were very musical, non-fatiguing, and overall very impressive (hard to impress me at a show).  He uses very high quality parts and first order crossovers in all his speakers.  Those crossovers make for easy loading on the amp and phase correctness between drivers.  I like guys that emphasize what goes inside and Fritz is definitively one of those guys.  Prices are more than reasonable as he sells direct and can deliver the veneer you want.
nickd
« Reply #13 on: 16 May 2020, 03:35 pm »
Hard to go wrong with these great drivers. If you like the sound of first order, series crossover’s the Carbon 7 sure seems like a real value.  Nice review.
jtcf
« Reply #14 on: 16 May 2020, 03:40 pm »
Thank you @hilde45 for your reply:)
usery
« Reply #15 on: 16 May 2020, 07:05 pm »
Yes thanks @hilde, great review - this nudges me towards Fritz in my own months-long search for standmount 'upgrade' from Nola Boxer v1's.  Are you still shopping?
hilde45
« Reply #16 on: 16 May 2020, 07:39 pm »
I am still shopping but may come back to the Fritz speakers. To be honest (and as I disclosed in the review) I'm really new to this level of speaker. I have a pair for trial ordered from Salk, but I hope to learn more about what I like so I know which to prefer. From a quality and enjoyment standpoint, Fritz's speakers were amazing.
usery
« Reply #17 on: 16 May 2020, 07:48 pm »
Salk standmounts are on my shortlist too.  Strongly recommend you look hard at this model, production of which Jim Salk picked up from Dennis Murphy of Philharmonic Audio: http://www.salksound.com/model.php?model=BMR+Monitors.  Appears to be near-unbeatable value given the components and in a Salk cabinet no less.  I haven't talked to Jim yet about current production status, turnaround time etc
Here's a review from Audioholics.com: https://www.audioholics.com/bookshelf-speaker-reviews/bmr-philharmonitor-1
« Reply #18 on: 16 May 2020, 08:19 pm »
Hilde, I just wanted to say you have excellent taste in music :thumb:
hilde45
« Reply #19 on: 17 May 2020, 12:44 am »
Hi usery — My speakers are being built and so I am not changing my order. Plus, I have tube amps and already changed my order away from lower sensitivity speakers with Salk to his 91 db SS6M model. So, I'm kinda committed.
Tyson —thank you for the compliment! Some of it is old favorites and some found its way onto my list because other audiophiles recommended the tracks/artists as especially revealing.
Lately, I've been checking out Blue Coast records. AMAZING recordings. Really sound stellar on my stuff. https://bluecoastrecords.com/
