Best place to get a 6080 or equivalent replacement
0 Members and 1 Guest are viewing this topic. Read 769 times.
NoDisco
I have a woo audio wa22. The tubes it came with are okay. Looking to replace the power tubes to bring this amps potential out completely. I have been looking all over recently for a great replacement. Everything seems sold out. I use the woo as a pre and headphone amp in my main rig. Thanks.
Escott1377
Re: Best place to get a 6080 or equivalent replacement
« Reply #1 on: 23 May 2020, 11:35 am »
I may get some negative responses on this 1 but check out EBay.
I just checked and there are quite a few up for auction.
Also, Tube Depot has them.
You can also run a search for its substitute - there a few out there, and then start hunting for those.
I have had good luck from EBay, even ordering tubes from as far as Russia.
Good luck!
« Reply #2 on: 24 May 2020, 10:49 pm »
Best tube brokers in US are Upscale and Andy at VTS.
6080 is a military version of 6AS7 that are made by Shuguang in large amounts.
