Receiver for my av3's?
0 Members and 1 Guest are viewing this topic. Read 1033 times.
Creative cut designs
« on: 10 May 2020, 12:44 am »
Receiver for my av3's is my older sony str-da50es would that be sufficient?
hawkeyejw
Re: Receiver for my av3's?
« Reply #1 on: 10 May 2020, 01:14 am »
The A/V-3s are 91db sensitivity and rated between 6-8 ohms so your receiver will be able to play them just fine. Is there going to be room for improvement? Sure, but I would recommend you don’t worry too much about perfecting the signal path immediately. Once you finish them, plug ‘em in and enjoy them. Then start figuring out how to optimize your room and components to get the most out of them.
« Reply #2 on: 10 May 2020, 01:31 am »
I actually temporarily hooked them up to make sure everything works before I close them and paint them
charmerci
« Reply #3 on: 10 May 2020, 05:19 am »
I found a generic Sony in a thrift shop for a few bucks. It doesn't have all the qualities of my more expensive equipment but it sounds pretty good!
Yeah, your receiver is fine.
« Last Edit: 10 May 2020, 01:52 pm by charmerci »
« Reply #4 on: 10 May 2020, 12:26 pm »
Back to n the day the es model was sony's high end models
S Clark
« Reply #5 on: 10 May 2020, 01:22 pm »
Just for grins you might look at a TDA 7295 amp.  For the cost of a Big Mac, the sound is actually really good.  Really good.
It kinda goofy, but a $4 Chinese chip amp actually sounds better than most of the big name receivers from the 70's and 80's.
There's been a ton of stuff written about them here at AC.
https://www.ebay.com/itm/12V-TDA7297-2x15W-Car-Digital-Audio-Amplifier-Dual-Channel-Module-Board-Kit-DIY/274249248271?hash=item3fda876e0f:g:2KIAAOSwjP9eOS90
« Reply #6 on: 10 May 2020, 01:41 pm »
I really don't know anything about stuff like that or how to hook it up
S Clark
« Reply #7 on: 10 May 2020, 02:31 pm »
No problem.  Old receivers are easy, cheapish, pretty decent sounding, and at every thrift store.
