Reasonable calibrated microphone
0 Members and 1 Guest are viewing this topic. Read 1439 times.
ctviggen
« on: 22 Feb 2005, 12:52 am »
Can anyone recommend a reasonable calibrated microphone?  I want to use it with my ETF program.  Thanks!
ted_b
« Reply #1 on: 22 Feb 2005, 01:06 am »
ETF sells a IBF-EMM8 mic/pre for $325 that is calibrated for ETF.  That's not a bad price.  (Edit:  Rives sells it for $250)
Ted
jackman
« Reply #2 on: 22 Feb 2005, 01:24 am »
What is ETF?  Thanks!
Jack
ted_b
« Reply #3 on: 22 Feb 2005, 02:00 am »
ETF is an acoustic measurement program.  It is a fairly sophisticated room measurement tool, especially helpful for bass problems (both fr and ringing).  Their waterfall plots allow you to see the time-based fr of your room (i.e see how well you can tame the ringing aspect of bass notes, an under-rated demon in bass problems).
http://www.acoustisoft.com/index.html
Ted
mac
Re: Reasonable calibrated microphone
« Reply #4 on: 22 Feb 2005, 02:07 am »
Quote from: ctviggen
You can spend more than $95 by not buying an ECM-8000/Rolls MP13 combo but I doubt you'll gain much increased accuracy.  Cheers, mac.
ted_b
« Reply #5 on: 22 Feb 2005, 03:12 am »
Mac,
Good call.  I don't know the MP13 pre but the Behringer mic is one my buddy uses and I forgot completely about it.  He uses it with his UltraCurve, I think, and claims it's quite good.
Ted
John Ashman
    • http://forum.adnm.com
« Reply #6 on: 22 Feb 2005, 05:16 am »
DEQX uses the behringer.  The have the Earthworks option which is extremely highly regarded, but even DEQX says that it's only a marginal improvement over the Behringer, but, of course, audiophiles live for that margins.
ctviggen
« Reply #7 on: 22 Feb 2005, 01:46 pm »
Thanks!  I can get the Behringer microphone plus MP-13 amp and a microphone stand for about $140.  That's not bad!
