SOLD: in-wall Thiel PowerPlane 1.2 underhung neo coaxial - $465 shipped CONUS
0 Members and 1 Guest are viewing this topic. Read 1271 times.
taloyd
Hello,
Been auditioning coaxials for years, trying to find the Cindarella one. Decided to go with Tannoy, in part because I was able to get three of them (it's for the LCR of a home theater/music system), and also because I didn't want to use an external amplifier - these are 4 ohm, and so need an decent amplifier (most receivers won't do a 4 ohm load). The Tannoys are 16 ohm so they're super easy for the receiver. In great shape (look completely new), have good boxes/packing for shipping. $465 for the pair, and I'll deal with the shipping costs. If you're local/near Los Angeles I can do less as I'll save on shipping.
These are a coaxial 2 way, using underhung motors for both the woofer and the tweeeter, and a 1st order phase-coherent crossover that Thiel is known for. Underhung motors are INCREDIBLY rare in speakers, as it costs a lot in magnets, almost always uses rare-earth magnets (these Thiel speakers use neodymium for BOTH the woofer AND the tweeter). But the result is that the voice coil is always saturated in the magnetic field, and so they're completely linear at all times (overhung motors are not completely linear/have more distortion).
Tal
Tweeter: 1 inch (2.5 cm) aluminum dome, 5 neodymium magnets, copper pole sleeve, short coil/long gap design, coincidentally mounted with woofer.
Woofer: 6.5 inch (16.5 cm) with anodized aluminum diaphragm, polystyrene reinforcement layer, stabilized by copper pole sleeve, short coil/long gap design, die cast chassis.
Product Highlights:
•1" aluminum tweeter
•6-1/2" aluminum midrange
•Coherent Source® technology
•drivers coaxially mounted for time coherence
•first-order crossover for phase coherence
•built-in aluminum cabinet
•short coil/long gap driver design eliminates distortion caused by variances in magnetic strength
•handles up to 200 watts
•frequency response 75-20,000 Hz (±3dB)
•sensitivity 89 dB
•4-ohm impedance -- suited for high-current amplifiers
•paintable aluminum speaker grilles
•cutout dimensions: 9"W x 15-1/4"H
•mounting depth: 4"
•sold individually
•weight: 9 pounds
PDF owner's manual:
https://manualzz.com/doc/2105139/thiel-audio-products-powerplane-speaker-user-manual
« Last Edit: 22 Jul 2020, 05:14 am by taloyd »
