L.K.S Digital Audio DA-004 DA005 (Updated) High-End DAC
Musiccean
Hi Audiophile From AudioCricle:
I am Chris, and our company is L.K.S Digital Audio,also known as Musound electronic, professional in the design and manufacture of DAC.
After six months of testing and adjustment, in March 2017, Musound finally completed the new es9038pro decoder mh-da004, which is positioned as the flagship of the series. The new flagship machine integrates the experience of Musound in the past decade and the use of many high-end parts, For example, Mundorf MCAP gold electrolytic capacitor, Crystek femtosecond clock, Guhe power socket, Cardas rhodium plated audio stand, AudioNote gold and silver alloy solder and Mundorf Supreme are used in key positions in Germany The flagship gold and silver solder has laid a very good sound foundation for this new decoder. At the same time, after repeated listening and adjusting by many fans, it makes the sound very natural, fax, excellent on-site feeling, rich details, high definition and transparency, abundant sound density, huge dynamic state, and the ductility of high and low frequency poles is very good. First of all, the shortcomings of the previous es9018 / 9028 in the sense of hearing have been improved, and the comprehensiveness of sound quality has reached a new height.More over,by Feb,2020, we have upgraded the USB module inside the DA004 to be equal to the independant device L.K.S digital audio USB-100 with Amanero solution, it means if the user buy the upgraded USB version of DA004, it is no longer necessary to buy and independant Amanero USB-100 again.
Mh-da004 provides two configuration versions:
The first is the Standard Version, which uses Italian amanero USB module. The module uses ordinary active crystal oscillator and is not equipped with independent power supply. When it is used, the USB module supplies power from the USB port of the computer after connecting the decoder and the computer through the USB cable.
The second is the USB upgrade version. The upgrade version improves the two most critical positions that affect the sound -- power supply and clock. Musound uses two expensive Crytek Cchd-957 ultra-low time base jitter active clock, and separately designed a ultra-low noise linear power module for the work of USB. This power module is directly powered by the AC transformer of the decoder, which can greatly optimize the power supply quality of the USB. The upgraded sound has the same characteristics as the high-end CDT, with open sound field, fresh and moist, full, transparent, excellent extension at both ends, The sound is high in density and very delicate, balanced and natural. The non upgraded ones are relatively flat, the high-frequency is slightly rough and protrusive, the texture is insufficient, the low-frequency is masculine but the level sense is insufficient.
For those who often use USB to connect computers, it is recommended that you choose the USB upgrade version.
The difference between the two versions is only in the USB receiving part, the other parts are completely the same, and the USB part will not affect the performance of other DAC interfaces.
■ product description -————————————————————————————————
Es9038pro is the flagship DAC audio decoder chip of ESS company, and also the DAC chip with the highest performance index. According to the practice of Musound, two es9038pro each are used to work in mono mode, which makes the two DAC chips handle the left and right audio content independently without interference, greatly improving the performance and hearing effect of the DAC. The official index of mono mode is 140dba dynamic range, which is 3dB higher than 137dba of single chip working in mono mode. The official index is only for reference, but it is easy to see the fact that in mono mode, the signal output current of DAC is twice as high as that in the Dual-track mode, and because the power supply of left and right channels can be separated, the darkness of the sound background, the density, separation, dynamic and imaging of the sound can be significantly improved.
As is known to the experienced audiophile, DAC chip is only the basis of a machine, the most important thing is the design and adjustment of peripheral circuits. In order to achieve the best sound replay effect by using es9038pro, Musound uncompromisingly designs the peripheral circuits, such as using two high-quality transformers to realize six groups of AC power supply, a total of 13 groups of low-noise voltage stabilizing circuits( Many key parts use two-stage voltage stabilizing method). The second stage voltage stabilizing adopts the most high-performance power supply chip in the industry to provide the power supply with enough current margin, quick response and ultra-low noise.
At the same time, in order to deal with the super current output (signal current over 100mA) under the unique mono mode of es9038pro, Musound specially designed the IV conversion circuit. This part of the circuit is a pure discrete part design, and the base materials used are audio triode, twin field effect transistor, audio medium power transistor, etc. with very low noise index at present. The silver mica capacitor is also used uncompromisingly, The purpose is to obtain the most accurate and natural sound reproduction. Such circuit mode is incomparable by traditional integrated operational amplifier output (such as opa627, ad797, lme49990, opa1612, etc.).
Musound designs in the most critical places as follows:
1. For the USB part, Musound always adheres to Italian Amanero solution, which is the leading USB solution in the industry. It is recognized that the sound of it is better than the popular XMOS, and it has been improved by Musound on the basis of the original Italian version. The USB module of the basic board uses six groups of ultra-low noise LDOS for partial power supply (the original version is two LDOS). Besides, in the USB upgrade version, Musound uses two Crytek ultra-low noise clocks to upgrade, and provides a decoder power transformer self powered ultra-low noise stabilized power module to power the USB module. The sound enhancement effect is significant, which is very suitable for the computer audiophile. And so one can save the cost of purchasing an external digital player.
2. The key position of the master clock. Crystal cchd-575 femtosecond clock is used to provide es9038pro with a very low jitter rate (82fs @ 100MHz) clock supply. Experienced audiophile know that when digital audio is restored, the clock is the soul of the system, so the importance of the clock can be seen. For the sake of the purity of the clock signal, Musound starts from the source power supply, uses an independent group of AC power supply regardless of the cost, and supplies the clock separately after passing through two-level ultra-low noise regulators, which greatly improves the quietness of the sound background and the stability of the sound imaging.
3. Musound designed independent power supply for two es9038pro DAC chips working on the left and right channels respectively, so as to reduce the power crosstalk of the left and right channels to a very low state as far as possible, which brings excellent sound separation and extremely accurate sound imaging stability.
4. Musound started to develop discrete circuit to replace the traditional op amp chip three years ago. Because the traditional op amp chip is limited by the chip volume and some congenital factors of SOC integrated circuit, the performance of the single parts that make up the internal circuit is very limited, and the thermal power consumption that can be borne is very low, and the static current of all the integrated op amp chips is in a very low state( Less than 10mA), even the advanced opa627 gold seal version in the minds of audiophile is not enough to handle the increasing audio output current of es9018 / 28 / 38 (the output current of es9018 / 28 in mono mode is about 30mA, while the output current of es9038 is more than 100mA), so the overall quality performance cannot meet the requirements by the audiophile. The discrete output circuit developed by Musound adopts twin JFET FET input and end pole 3A medium power transistor output, which can easily meet the high current output processing of es9038pro. After more than 100 circuit parameter adjustments in three years, the sound performance is extremely natural, and the ductility of medium, positive, high and low frequency is excellent.
5. It has a high standard analog output circuit. In order to achieve the best effect with this circuit, Musound specially designed a Class A (Class A) power circuit of the same high-grade level, Hengliuyuan circuit mode design, Ansenmei high power regulator, and used mondorf electrodialysis, with appropriate output capacitance and decoupling capacitance, the sound is natural, transparent, very balanced and It's very musical.
6. In the high-end system, every tiny detail that affects the sound cannot be ignored. Musound uses Guhe fi03 gold-plated power socket, cardas rhodium-plated RCA Audio output socket, Neutrik balanced output socket and so on. These parts are the most familiar to audiophile. It is precisely the adoption of these key parts that can create a good sound system. Musound is equipped with Swiss Shute frozen fuse as standard for customers. The sound is delicate, warm and quiet. It is obvious that the common fuse is rough and grainy.
All ports of MH-da004 DAC support DSD input (coaxial, optical fiber, BNC, AES / EBU support DOP input, USB, I2S support DOP, DSD native source code input)
All on-line decoders of Musound are designed with full balance analog circuit. So don't ask if it's true balance.
The Italian amanero USB module used in this machine supports PCM and DSD decoding under USB access mode. PCM supports 44.1k ~ 384k various bit rates. DSD supports dsd64, dsd128, dsd256 and dsd512 (Windows).
Windows system supports 32 / 64 bit XP / Vista / win7 / win8 / win10, and requires the installation of proprietary drivers (KS / wasapi / WDM / ASIO is supported).
Mac OS 10.6 + and Linux uac2 do not need drivers.
Thank you for your support to L.K.S Digital Audio!  L.K.S Digital Audio is one of the earliest companies in the development of ESS series decoding products in China. It focuses on the development of decoders and has a deep understanding and exploration of ESS series. The products have been customized and developed for many companies at home and abroad since 2012 for more than 5 years, and the customers response are very good. We in line with the attitude of continuous improvement, carefully improve each of our products, and treat each of our customers as the God. Choose us, we will provide you the best service and commitment!
You can reach us by our website http://www.mu-sound.com/index.asp or contact me for English service directly through [email protected]. Thanks.
« Last Edit: 30 Jun 2022, 04:32 am by Musiccean »
marvda1
  • freelance reviewer: The Sound Advocate
Re: L.K.S Digital Audio DA-004 High-End DAC
« Reply #1 on: 16 Apr 2020, 03:34 pm »
i have one of your da-004 dacs and love it.
I.Greyhound Fan
« Reply #2 on: 16 Apr 2020, 04:48 pm »
Prices for the DAC's?
marvda1
« Reply #3 on: 16 Apr 2020, 05:22 pm »
amazon has the model with upgraded usb at $1599.98 and standard usb at $1459.98
erniejade
« Reply #4 on: 16 Apr 2020, 05:52 pm »
I was actually thinking of picking this dac in the near future.
erniejade
« Reply #5 on: 16 Apr 2020, 05:54 pm »
Do you have any plans for MAQ on this Dac?
Early B.
« Reply #6 on: 16 Apr 2020, 07:45 pm »
Are there any manufacturer recommended sonic upgrades available for this DAC?
Musiccean
« Reply #7 on: 17 Apr 2020, 06:11 am »
We have promotional plan now,shipping direct from our company with full warranty, you can send me email [email protected] or join my wechat 13242019221 for more information,thanks.Many audiophile consider our DAC DA004 as the same class as some much more expensive DAC such Dave. Though it is definitely subjective,but it is worth a try.
Musiccean
« Reply #8 on: 17 Apr 2020, 06:12 am »
Thank you my friend.
Musiccean
« Reply #9 on: 17 Apr 2020, 06:52 am »
We have promotional plan now, you can contact me by [email protected] for more information. Thanks.
Musiccean
« Reply #10 on: 17 Apr 2020, 06:54 am »
not yet so far.
Musiccean
« Reply #11 on: 17 Apr 2020, 07:06 am »
If you are a PC audiophile, it is recommended using the Amanero USB 100 or buy our latest USB upgraded version DAC, the built-in module has been optimized to be as good as the independant Amanero USB 100 2 months ago. If you want to achieve better sound, a high-end digital player and amp are also needed.
erniejade
« Reply #12 on: 20 May 2020, 09:49 pm »
Received the Dac in Silver. Fantastic unit!
Musiccean
« Reply #13 on: 30 Jun 2022, 04:00 am »
Our LKS 005 have been ready for a while.which is a huge step up than 004,welcome contact me for a discount.
Musiccean
« Reply #14 on: 30 Jun 2022, 04:28 am »
The design of Musetec's new flagship DAC mh-da005 has condensed Musetec's more than 10 years of experience in the decoder field. The overall development process took one and a half years.
The original design intention of DA005 is to produce a DAC whose sound, appearance and process level are higher than those of DA004, rather than the optimization and update of DA004. Different design objectives have established the level gap between DA005 and DA004.
In order to achieve this goal, the motherboard has been proofed for 6 times, the power board has been proofed for more than 20 times in different replacement schemes, and dozens of spare parts have been tested.
1、 Newly designed power supply system
The power supply in the sound system is extremely important. We have designed an advanced power regeneration system for DA005, which is like two storage ponds. When one group discharges water, the other group stores water, and the cycle alternates. Under the well-designed control logic, the storage and discharge are completely isolated and do not affect each other, so the impact of mains noise on the main circuit of DAC can be avoided to a great extent. On the other hand, the circuits powered by the traditional iron core power transformer have the problem of poor load adjustment rate, which leads to the dynamic compression of sound and insufficient density. The new power supply system does not have this problem. The quiet, abundant and high-quality energy supply DAC circuit can replay the most authentic sound.
In the DAC power supply circuit, we use a large number of industry-leading high-performance low-noise regulators from Lingte linear, Ti and other companies to ensure that each functional circuit has an independent two-level voltage stabilizing supply, providing pure static and sufficient energy for each part of the circuit. A total of 18 independent regulators were used.
The power supply of analog circuit is also very important. We have specially customized an O-type transformer. The primary and secondary windings are made of expensive single crystal copper silver plated material. Due to the skin effect of AC, the current basically flows through the silver layer on the surface. Compared with copper wire and oxygen free copper wire transformers, the sound is essentially different, more quiet, pure, delicate and full, and the transient response is more excellent (compared with the same conditions). In addition, it is sealed with high-strength stainless steel shield to resist mechanical vibration and realize electric field shielding. The newly designed analog power supply circuit adopts high current and low internal resistance power MOS as the regulator in the circuit structure, and twin discrete components form a voltage feedback control circuit to achieve very low output internal resistance and very low power supply noise. It can provide fast and sufficient output response in all frequency bands of analog output circuit.
The rectifier diode adopts silicon carbide Schottky diode without recovery time. The main filter capacitor is a mundorf non inductive electrolytic capacitor, and the output capacitor is an audioote fast clear non-polar capacitor with mundorf supreme capacitor for high-frequency compensation.
The reverse recovery time of SiC Schottky diodes approaches zero, the switching speed of on and off states is very fast, and there is no reverse recovery current when ordinary bipolar diodes enter the switch. Because of the existence of reverse recovery current, the gap between cut-off and on will produce very large pulse spikes in the traditional silicon-based or germanium based bipolar diodes in the switching rectifier circuit, which will directly interfere with the performance of the back-end circuit. As a result, the sound is rough and burry. The silicon carbide diode is much more stable and smooth, and the sound texture and details are more prominent. In terms of cost, silicon carbide diode is more than 10 times that of ordinary Schottky diode.
2、 Analog output line
The analog output circuit of DA005 adopts the newly designed full discrete component circuit. The advantage of discrete components is that the single diode and triode with excellent characteristics can be selected, and the sound is more comprehensive than the integrated operational amplifier. DA005 uses a large number of twin JFETS and twin triodes, and the circuit has higher accuracy. Both balanced output and single ended output have the same LPF low-pass filter circuit. DA005 adopts small volume, low-temperature drift (no more than 5ppm) and high-precision (0.01%) non inductive resistance, making the sound more vivid and fax.
Single end output terminal, we use customized high conductivity tellurium copper gold-plated RCA plug, Teflon inner core, and Duran gold silver alloy wire for lead out.
High conductivity tellurium copper alloy. Its main excellent properties are introduced: 1) it has very high conductivity. The conductivity of tellurium copper alloy is 94%-98%, gold is 65 ~ 75%, rhodium is 35%, and brass with high copper content is 28%; 2) It has high thermal conductivity. 22% more than pure silver and 28% more than red copper; 3) Good arc resistance.
In the analog circuit, there are also two particularly important capacitors. We compared a variety of expensive copper foil, silver foil, gold and silver foil, oil immersed and other capacitors, and finally chose German GAD gold and silver foil capacitors. Compared with GAD gold and silver foil capacitors and mundorf flagship gold and silver foil oil immersed capacitors, GAD gold and silver foil capacitors have more solid internal materials (from the manufacturer's introduction), fuller full frequency, higher density, richer details and stronger texture. GAD gold silver foil capacitors are also more expensive.
3、 Clock system
The DA005 complete machine (including USB circuit) uses four high-performance clocks, and its quality exceeds that of Crytek cchd957 and cchd575 series widely used in high-end computers.
Taking the 24.576mhz in cchd957 series as an example, the most critical sideband noise of 10Hz at the near end is -97.9db √ Hz, and the customized clock of DA005 is -108.6db √ Hz, with a noise reduction of nearly 10dB. The direct benefit is that the sound is more natural and accurate. (compared with external conditions)
4、 Auxiliary material design
The internal wiring of DA005 uses a large number of high-purity Jensen pure silver wires. Compared with 7n single crystal copper wire, pure silver wire has higher sound density, and more excellent details, texture, sound field, permeability and smoothness.
The single end output terminal of DA005 is connected with tellurium copper alloy and Duran gold silver wire.
5、 Built in high-performance USB interface
Specially designed high-performance USB interface, Italy amanero scheme, four layer board design. Using multi-channel low-noise power supply, three excellent low sideband noise clocks (better than Crytek cchd957). The high-speed isolator can isolate the ground wire of the computer by 3KV. Make the sound more pure.
In USB access mode, PCM and DSD decoding are supported. PCM supports 44.1k~384k bit rates. DSD supports dsd64, dsd128, dsd256 and dsd512.
For the setting mode of USB drive and computer player, please refer to the documentation in the USB drive attached to the machine.
6、 Main parameters
Decoding chip es9038pro x 2
Input channel: USB, coaxial 1, coaxial 2, optical fiber, aes/ebu, i2s-e, i2s-h
Single ended RCA output level 2Vrms
Balanced XLR output level 4vrms
Digital volume attenuation function, with 0.5dB interval attenuation, can be skipped
Digital filtering mode optional
Digital PLL DPLL settable
DSD channel switching function that can be set
De emphasis function that can be turned on and off
DOP (DSD over PCM) receiving function that can be turned on and off
USB supports pcm44~384k, dsd64~dsd512
I2s-e and i2s-h support pcm44~pcm384k, dsd64~dsd512 and dop64x
Coaxial, optical fiber, aes/ebu support pcm44~pcm192k, dop64
Full function remote control with remote standby function
VFD display screen with multi gear brightness adjustment and automatic screen stop
Dynamic range >136db
Distortion <0.0002%
Stereo resolution >120db
Frequency response 0~20khz ± 0.2db
Rated power 25W
Size 430*350*78mm (width * depth * height), height including machine feet
Net weight of the machine: 9.0kg
Power supply voltage 100~120v or 200~240v optional
7、 Summary of characteristics:
Muconic advanced regenerative power supply system, supplemented by precise power supply monitoring circuit
Up to 18 high performance low noise regulators
Four very low sideband noise clocks
O-type single crystal copper silver plated cow
New analog power circuit structure
Silicon carbide diode without recovery time
Mundorf main filter capacitor, audioote fast clear electrodeless capacitor, mundorf supreme capacitor, GAD gold silver foil capacitor, MIT capacitor
8 groups of discrete individual circuits provide fully balanced and single ended output, fully discrete design, twin tube, low temperature drift 5ppm non inductive resistance
Tellurium copper plated Teflon core RCA output terminal with Duran gold silver alloy lead
In machine Jensen Sterling Silver wiring
Guhe fi-03g power tail plug
The motherboard is designed with six layers of sinking gold plate
High grade aluminum chassis
Large size VFD display
8、 Sound characteristics
The decoder is a part of the sound source in the sound system. It is very critical to grasp the lifeline of sound in the whole system. Reasonable cognition is that the sound source needs to be neutral and accurate, and Z is close to the nature of recording to a large extent, so that it can give full support to the faithful playback of the back-end system. Therefore, the design and adjustment of DA005 also adhere to the characteristics of neutral and neutral. Due to the new circuit architecture design and the generous selection of materials, the sound texture, density, sound field, level, transparency, fineness, smoothness, detail Compared with 004, micro dynamics has significantly improved. In a strict sense, it has crossed several levels, showing a high level in terms of sound and musicality, and has a comprehensive and true expression of various types of music. Especially for the improvement of the intermediate frequency band, it can be said that the es9038 has the characteristics of texture but not full and emotional sound.
9、 Packing list
Remote control
American standard power cord
USB line
T2 hexagon socket screwdriver (used to remove the remote control and replace the battery)
USB flash disk (including electronic manual, the machine will not provide paper manual)
warranty card
Musiccean
Re: L.K.S Digital Audio DA-004 DA005 (Updated) High-End DAC
« Reply #15 on: 30 Jun 2022, 07:13 am »
Ebay price:3299usd or more, we have a promotional plan at the moment, contact me through [email protected], get a good discount.
Musiccean
nc42acc
« Reply #17 on: 30 Jun 2022, 05:13 pm »
I bought a LKS DAC a few years ago and it arrived dead out of the box. I never received any resolution and finally received a refund but did not get any shipping provisions to return the DAC. I still have the DAC put away somewhere. Do you have any repair facilities now for possible issues? Thanks
Musiccean
« Reply #18 on: 1 Jul 2022, 01:23 am »
I used mine around 3 years and nothing happended. I suggest you go to the hifi device repaire shop to have a check, could be some component damaged during shipping.
