Tutorial on how to shrink a HAL-O III damper
plasmapan
« on: 15 Apr 2020, 05:54 pm »
Hello,
I bought a pair of HAL-O III "50" stabilizers to treat a pair of Mullard GZ32's. The tube is 46mm in its widest point where I'd like to place the HAL-O III
Size of the GZ32 :
How to shrink the HAL-O III (that's too large) without harming it?
Is there a video tutorial or something?
I apologize if this question was already asked. I didn't find it.
Gianluca
Wind Chaser
Re: Tutorial on how to shrink a HAL-O III damper
« Reply #1 on: 15 Apr 2020, 07:50 pm »
I don't think they are shrinkable.  :dunno:
Anyhow, welcome to Audio Circle.  :D
« Reply #2 on: 15 Apr 2020, 07:57 pm »
Obviously you have to tighten the ring at your own risk, is there need a tutorial for it?
« Reply #3 on: 16 Apr 2020, 02:57 pm »
As may be difficult model with precision the spring effect of a metal bar, in this case titanium I could suggest you dont modify the metal ring and use felt pads or rubber pads under the wheels, if this rectifier works hot you will need keep a eye on the pads temperature to avoid a fire though.
plasmapan
« Reply #4 on: 2 May 2020, 04:09 pm »
Thank you for your replies!
I succeeded to tighten the HAL-O III dampers in order to adhere to the GZ32's. I applied a certain strenght but they don't seem to have suffered much.
Gianluca
