Airplay to IDA-8
0 Members and 1 Guest are viewing this topic. Read 1877 times.
gordon
Airplay to IDA-8
« on: 14 Apr 2020, 12:38 pm »
What device do you recommended to connect to the IDA-8 to receive Airplay from an iPad or iPhone?
avta
Re: Airplay to IDA-8
« Reply #1 on: 14 Apr 2020, 02:24 pm »
Apple Airport Express is an inexpensive solution. Apple sells refurbished units.
gordon
« Reply #2 on: 14 Apr 2020, 03:16 pm »
Thank you, that’s a big help. Is the connection to the IDA-8 via USB port that Nuprimes dongle was designed for?
avta
« Reply #3 on: 14 Apr 2020, 03:39 pm »
If I remember correctly you would use an optical cable from the AE to the IDA 8.
gordon
« Reply #4 on: 14 Apr 2020, 04:13 pm »
Got it, that makes sense, thanks again.
jtmsrl
« Reply #5 on: 14 Apr 2020, 10:48 pm »
I bought a TuneBox 2 from amazon, you can plug it into the USB for power and digital in. Not sure if it has Airplay, but it do have spotify
happyrabbit
« Reply #6 on: 15 Apr 2020, 04:32 am »
https://us.audiopro.com/product/link-1/#
Cheapest Airplay device with a toslink I could find.  I own two of them.  One is hardwired and other is WiFi connected.
Dwight.
gordon
« Reply #7 on: 17 Apr 2020, 02:16 am »
Thanks Dwight, had never heard of the audio pro, will pick one up and give it a try.
