Poll
Which of these would be a significant upgrade over a Modi 1?
Chord Mojo ~350
1 (11.1%)
Benchmark DAC1 ~350
1 (11.1%)
Topping DX7S ~350
2 (22.2%)
SMSL M500 ~400
1 (11.1%)
Don't spend now, upgrade at ~600-700 a year later
4 (44.4%)
Total Members Voted: 9
Best DAC+ HP amp under $400? Need help
musicgeek
« on: 9 Apr 2020, 09:03 pm »
Open to other suggestions too! Bluetooth would be a huge plus...
I need both RCA and headphone outs, will move between a desktop setup and HT setup..Will be used with external pre and power amps so a clean/basic analog path is desirable.
Do new DACs of lower price match up to higher ups from the past in SQ?
rollo
  • Rollo Audio Consulting -
Re: Best DAC+ HP amp under $400? Need help
« Reply #1 on: 9 Apr 2020, 09:22 pm »
  Check out Schitt. Not a dealer of Schitt.
charles
charmerci
« Reply #2 on: 10 Apr 2020, 01:53 am »
I have older pretty high end Audio by Van Alstine (Ultra) DAC and recently bought a Schiit Modi 3 and though it doesn't have the depth/soundstage of the AVA and not quite the ultimate low bass and extended highs, it sounds comparatively nice.
Sparky14
« Reply #3 on: 26 Apr 2020, 04:20 am »
I'm considering the exact same thing.
Audio-gd has the R2R-11 at $350. Also, ESS9028 and ESS9038 based all-in-ones around $400. I had a lot of audio-gd rigs 10-15 years ago, they make great gear.
But, like you, I will be transporting from work to home a lot, so also considering the smaller SMSL and Topping ones as well.
cujobob
« Reply #4 on: 15 May 2020, 03:00 pm »
There are some truly excellent DACs out right now in the low budget range. I'd opt for the SMSL Sanskrit one for $99, or the Topping E30 for $130 (I'd go for the Topping, myself).
As for a headphone amp, the various versions of the THX amplifiers are the best right now and they're pretty affordable. The one from Drop is now $300, Monoprice and SMSL also carry versions for around the same price...all sound pretty similar. If you want to go cheaper, the JDS labs Atom is fantastic, too.
You're not going to find a huge difference amongst well designed DACs unless you get one that is technically inferior (multibit) which adds some 'warmth' to the sound. Nothing wrong with that, if you're into it. Myself, I'd just put a tube in the system somewhere if I were looking for something to add depth and warmth to the sound.
The Soncoz LA-QXD1 seems like it'll be an absolute beast of a DAC around $200, but no remote (if you care about that). It's also balanced. That would be the next step up from the Topping E30, though I can't say the improvements are audible at this level of performance.
dflee
« Reply #5 on: 15 May 2020, 06:03 pm »
I'd recommend IFI.
Took a pretty big price difference to beat it.
Don
Sparky14
« Reply #6 on: 15 May 2020, 06:11 pm »
I opted for the Sabaj D5 with the $399 HiFiExpress deal. After 1 week, I could not be happier.
cujobob
« Reply #7 on: 15 May 2020, 06:40 pm »
Nice grab, that's a fantastic unit. I always seem to miss out on the deals there.
musicgeek
« Reply #8 on: 16 May 2020, 07:01 pm »
I ended up with the Sabaj D5 as well! Such a sweet sounding yet detailed dac!
