Odyssey Audio Khartago Monos
0 Members and 1 Guest are viewing this topic. Read 1137 times.
mike_p
  • You Never Blow Your Trip Forever
« on: 8 Apr 2020, 01:24 pm »
Reliable, musical, high current amps stable down to 2 ohm loads. Pair of Pangea amp stands included.
See Jonathan Valin's review of the stereo version: http://www.theabsolutesound.com/articles/tas-195-odyssey-audio-khartago-stereo-amplifier/
$1,275 + shipping from Rochester NY, or local pickup. Pls add 2.9% for PP.
The specs:
Odyssey Khartago Mono Plus SS amps, 1 x 110 Watts RMS @ 8 Ohms (each) 2 Ohm load stable Class A/AB 1 - 600,000 Hz frequency range 120,000 µF memory (each) 120 amps current delivery <0.04% THD (not audible) >800 continuous damping factor Input impedance 22K ohms DC offset <1 mV RCA inputs 400 VA Plitron transformer (each) Additional 60,000 µF memory bank for 120,000 µF total Sanken Epitaxial Planar Transistors 2SA1216 & 2SC2922 Anti vibration dual thickness PCB Power consumption when idle ±30Watts 4 internal fuses 250V/6.3A, 5x20mm, fast blow Additional electrical protection fuse
