Studio monitor build question
0 Members and 1 Guest are viewing this topic. Read 843 times.
mlundy57
« on: 5 Apr 2020, 06:49 pm »
Instead of having a grill frame that's 3/4" thick, is there any reason why the sides and back can't be 3/8" taller resulting in a 3/8" thick grill frame? A 3/8" filler piece would have to be added to the front baffle above the tweeter, but that's not difficult.
Sonicjoy
Re: Studio monitor build question
« Reply #1 on: 5 Apr 2020, 08:27 pm »
I don't see a problem with that. Won't change the performance. You would just be moving the dividing line between the speaker and the grill up, the over all height will not change. Might be a cleaner look. I like it. I even thought of making the side panels the same height as the baffle and recessing the grill into the top. That could be an even cleaner design.
« Reply #2 on: 6 Apr 2020, 06:08 pm »
That was what I intended when we designed the baffle.  If we get some flat packs going,  they  will be done  like this
jay
Wind Chaser
« Reply #3 on: 6 Apr 2020, 06:31 pm »
Jay,
How likely is that to happen?
« Reply #4 on: 6 Apr 2020, 08:18 pm »
It is being worked on,   just  really busy with stuff .... trying to catch up.
jay
