Amplifier recommendation for 95db 4ohm OB speakers?
0 Members and 1 Guest are viewing this topic. Read 2127 times.
Jflemelin
Just wondering what I could use in terms of amplification for my DYI OB speakers. They do dip to about 4.5 ohm around 60HZ, but they're between 6 and 8 ohm from 85HZ. Phase is very well behaved above 60HZ ( pretty flat between 0 and +25 degrees). My room is large (9' ceiling. 20 X 35 ft).
I'm all ears for your recommendations.
JF
rollo
  • Rollo Audio Consulting -
Re: Amplifier recommendation for 95db 4ohm OB speakers?
« Reply #1 on: 24 Mar 2020, 07:07 pm »
  15W and up tubed Amp. Or integrated. What pre and front end are you using. easier to recco an Amp with that info.
charles
Rocket_Ronny
    • ScriptureSongs.com
« Reply #2 on: 24 Mar 2020, 07:49 pm »
Ha, I was going to say 6 watt min.
All depends on the voicing of the speakers and system, then what your sound priorities are. Almost any amp will do.
Rocket Ronny
Jflemelin
« Reply #3 on: 24 Mar 2020, 09:08 pm »
charles
Right now I have a small 50w SS integrated. Could use it as a pre for a transitionnal period, but I'll need a pre if I go for separates. I already have a decent size stash of 6SN7's, 12AU7's and a matched quads of 6L6's, KT77's, 7581.
Freo-1
« Reply #4 on: 24 Mar 2020, 09:13 pm »
Look at First Watt amps. The SIT amps would be especially of interest.
Jflemelin
« Reply #5 on: 24 Mar 2020, 09:13 pm »
Rocket Ronny
It's voiced fairly flat. -3db @ 45hz. I listen to pretty much everything from jazz trio to orchestral, electronic, metal, blue grass... Everything really. So I'm looking for something that has high dynamic headroom.
Jflemelin
« Reply #6 on: 24 Mar 2020, 09:14 pm »
Grinnell
« Reply #7 on: 2 Apr 2020, 03:17 pm »
Decware mini Torii. 4 watts. 10 tubes. clean rich sound
rodge827
« Reply #8 on: 3 Apr 2020, 01:56 am »
Here is a very good integrated  https://www.canuckaudiomart.com/details/649485847-ank-el84-l1-kit/
Buy it there or the kit from ANK the el34 and El84 kits are very good. They also have a build service.
https://www.ankaudiokits.com/product-category/el34-amps/
https://www.ankaudiokits.com/product-category/el84-amps/
If going solid state look into the Digital Amplifier Company they have a forum here on AC and Tommy is an awesome guy to talk to about his products.
Rusty Jefferson
« Reply #9 on: 3 Apr 2020, 03:28 am »
Consider the Linear Tube Audio amplifiers designed by David Berning.  Tube amplifiers that have low output impedance and will not be bothered by that impedance dip.
« Reply #10 on: 3 Apr 2020, 03:44 am »
First Watt SIT amps are great but $4 grand, if Class D amps are welcome see Maraschino STM at $1200
morganc
« Reply #11 on: 3 Apr 2020, 03:53 am »
I was always a tube guy, but now have the king STM and love it so much I'm moving up the line to a 2-Cherry. I'm also gonna get an LTA tube amp and swap the two. The dynamic headroom of the Digital Audio Cherry amps is great with my Spatials.
