I would suggest running three to four dedicated lines to your room. One for all digital, one for preamp,phono,etc. then two for amp or amps. If not using mono blocks than three lines will suffice. Include an after market duplex outlet as well a big plus. In every installation using several dedicated lines was always more affective than one line with ANY power conditioner. The ultimate is a conditioner for each dedicated line. Which one ? that is your choice. charles
Yes, I've noticed sometimes that you don't get answers over at PS Audio's forum when you would expect to. I suppose people don't check in as often at such a narrowly focused group. I tend to check in here and at Audiogon more often. I assume Speedskater is saying that a dedicated line is better than a regenerator in his last post. He's a knowledgeable enthusiast for sure, but there are those that would disagree with his supposition that dedicated lines are always a better expenditure than power conditioning or regeneration. There are audiophiles with systems at various price points I'm familiar with who have tried both approaches and preferred regeneration/power conditioning over dedicated circuits. I've heard wonderful systems with both approaches implemented. As with most things in this hobby, it seems that variations in equipment, tastes, and native power conditions affect how people perceive the relative value and efficacy of each approach. I have an odd wall arrangement in my listening room and a longish run from the mains entrance into the house, so it would be a somewhat expensive proposition to try a dedicated line to my equipment. I would like the opportunity to test both approaches for myself. I will say the PSA 3 regenerator improved the performance of my front end equipment by such a large margin I'd consider it essential now.
It's much better to have one heavy (120V) feeder from the main breaker panel to the room and a 6 breaker box in/near the room. Most hi-fi rooms and small semi-pro studios only need one 20 Amp circuit.
Thank you so much Buddy! I appreciate your response and insight. I just had no idea the 'order' in which to plug things in; the Naim PSUs being the outliers in all of this. No matter how much I researched the idea of plugging in an external power supply to a PS Audio regeneration-type device, I just couldn't find the answer. It made some amount of sense to plug the PSUs into the P3, but having to plug the components into the strip or wall made me wonder if they were benefitting from the P3. I will experiment with the SuperNait direct-to-wall versus hi-current on the P3. The suspense is killing me. It has been too long without a system in place to listen to music.Thanks again, seriously.
Hey! No problem at all! There's one thing that I should mentioned. With only 300 watts available... and I'm not familiar with the Naim PSU thingy. Before you plug things in the P3, what you should do is find out what is the maximum wattage consumption each component or outboard PSUs are, add them up and make sure you don't go above 300 watts. But personally... ideally I think it is best to leave some headroom maybe at not exceed 250 watts total. I see that your turntable's PSU regenerate the power. I would still try plug it in P3 and see how it sound. Actually, with the turntable's PSU regenerate it own power, because of that you can try out different sine wave instead of standard 60hz without effecting the turntable. I can't do that since my turntable have AC sync motor, so if I increase the sine wave from standard 60hz on my P600 I also speed up my TT! But I did tried higher sine wave before playing CD but honestly I think I like it just fine at the standard 60hz. And one more thing... once you put the P3 in your system, give it a week to settle. And don't do quick switch between it and direct to the wall or other power conditioner. Set you system up with the P3, listen to it for 2-3 weeks or so and then take out the P3 and plug everything to the wall. You'll see the difference, and then you can decide if you like it or not. Buddy
Yes one 20A to a sub-panel. Agree We run the dedicated lines from the sub-panel [4] all 20A. We use two for mono block amps. one for digital and the last for analog[ TT, phono stage]. Each line has a conditioner. Works very well for our demos.charles
I assume Speedskater is saying that a dedicated line is better than a regenerator in his last post.Two different subjects, entirely .My post was on how to run AC power to an audio room. The basic idea is to have all the audio component's chassis at about the same potential. So short Safety Ground/Protective Earth conductors from component to component is the best plan.
