Isolation transformer questions
0 Members and 1 Guest are viewing this topic. Read 9039 times.
Syrah
Re: Isolation transformer questions
« Reply #20 on: 20 Sep 2011, 02:23 pm »
Perfect.  Thanks. So could/would I put,
- one 7 amp circuit breaker on each hot leg, or one 3.5 amp on each hot leg;
- the circuit breakers on the 120-0-120 end or the 60-0-60 end?
I would think the 120-0-120 end would sound better since whatever damage is done to the signal gets the trannie to fix it, as opposed to the 60-0-60 end.  But as is clear from my question - I am NO expert.
Thanks again guys!
Occam
« Reply #21 on: 20 Sep 2011, 02:47 pm »
Syrah,
As you surmised, a [<=] 7 amp on each of the hot legs of the (defacto) primaries, those that are fed the 240vac housepower.
Paul
Syrah
« Reply #22 on: 27 Nov 2011, 09:59 pm »
Hi Guys.  I finally wired this up.  My fuses blew as soon as I threw the switch.  I suspect I either wired it wrong or it's a defective trannie.
To be clear, the "0"s on both the primaries and secondaries are all wired up together and grounded.  Then I fed the 240 taps with 120-0-120, hoping to get 60-0-60 out of the secondaries.  No such luck.  Should the "0" on the primary or secondary end not have been grounded?
Speedskater
  • Kevin
« Reply #23 on: 28 Nov 2011, 02:53 pm »
OK download this white paper from Middle Atlantic:
http://www.middleatlantic.com/pdf/PowerPaper.pdf
Go to page 21 for the correct wiring diagram.
Syrah
« Reply #24 on: 28 Nov 2011, 03:12 pm »
Thanks for this!  So on the 120-0-120 primaries I need to connect the 0s to each other.  Then on my secondaries I need to connect and ground the 0s.
So only the secondaries 0s are grounded.  My mistake was grounding both.
Syrah
« Reply #25 on: 1 Dec 2011, 07:02 pm »
Alright.  Well I've been blowing fuses all over the place trying to wire this properly.
I called Signal.  They said to wire it in series on both the primaries and secondaries, which should solve my problems.
So on the 240 primaries, I connect one O with one 240, and hook my two hot 120 lines to a 240 and a 0.
Then on the 120 secondaries, I connect one 0 with one 120 and ground both, then tap the other 0 and the other 120 to get 60-0-60 out.
Any objections to this?
Will it still give me technically balanced power out?
What would have happened if I connected and grounded the two 0s on the secondaries and tapped the two 120s instead?
Syrah
« Reply #26 on: 1 Dec 2011, 09:35 pm »
I just read this from an online tutorial,
"Antiphase wiring will not harm a transformer when wired in series (although the zero volts output for equal windings is somewhat limited in usefulness). Parallel antiphase connection will destroy the transformer unless the fuse blows - which it will do mightily. Always use a fuse when testing, as a simple mistake can be rather costly without some form of protection for the transformer and house wiring!"
Is this what I did wrong the first time?  Since my primaries and secondaries were reversed, should I have put the hot 120s on the two 0s and connected the two 240s to each other?
Speedskater
  • Kevin
« Reply #27 on: 7 Dec 2011, 03:38 pm »
Syrah, did you solve all your wiring problems?
Syrah
« Reply #28 on: 7 Dec 2011, 04:40 pm »
I did thanks. Occam set me straight. Thanks again Occam!
It sounds great. I have the trannie powering two PS Audio P300s that I use to power my pre-amp, phono stage and sources.
The 120-0-120 from the wall stepped down to 60-0-60 with the SU-3 (in reverse) seems to produce additional clarity to everything as compared to the 120 from the wall converted to 60-0-60 with the DU-2.  I'm not sure whether its because of common mode filtering from the 120-0-120 line, a bigger trannie, lower impedance, etc.  But it definitely sounds better.
