Pretend you have up to $3000 to buy an integrated SS amp. Which would you buy?
charmerci
This thread has taken on a life of its own. I suppose SS could be misconstrued to mean stainless steel.   :lol:
I'm sure it would have died if the original post title was "Which should I buy?" rather than "Which would you buy?" and you actually bought one!
« Last Edit: 18 May 2020, 03:10 am by charmerci »
Has for a long time, I think it's basically a Khartago with a volume control.
http://www.odysseyaudio.com/products-cyclops.html
I have seen it for years, what would be good would be a Stratos with a 6SN7 tube preamp in the same chassis, Candela not count.
tonnesen
I'll revive this thread again since I was also looking for a SS amp and happily found a used Pass INT-25 (the XA25 with and a built in  preamp).   There were no options to audition so I bought it purely on the awesome reviews and the Pass Labs reputation.   I also like the very simple design of the amp, it has exactly what I need and nothing more. Class A for the first 25 watts.  The Absolute Sound review of the Micromega did mention a "meaningful improvement" with the Pass XA 60.8 monoblocks compared to the Micromega.  I'm guessing you would get the same improvement, and maybe more, with the INT-25.
AvsFan
Hands down, a Hegel. I’ve had my Rost for two weeks now. All I can say is WOW.
Major Dolphin
Yamaha A-S2200
HT cOz
Big Red Machine
Are Hegels Class D?
Bemopti123
Are Hegels Class D?
They seem to be Class AB but I can be wrong.
mav52
/mp
Solid State only, please.
New or used; 150w/ch minimum. DAC included is a plus, but not absolutely necessary.
It depends on the speakers it will power.
AvsFan
Yamaha A-S2200
Don't tempt me! I came close to buying the one here on AC but went the Hegel route.
AvsFan
Are Hegels Class D?
Nope, Class A/B.
They do have a lot of technology built into their amps and do things a little different. Here is a link.
https://www.hegel.com/technology
mresseguie
I was fortunate to listen to a Hegel H160 powering a pair of Harbeth M20.1 speakers in Taiwan a couple years ago. [I believe they're nearly identical to the PS7ers.] I was astonished by how much bass came out of the small speakers.
jjss49
https://www.audiocircle.com/index.php?topic=173265.msg1830747#msg1830747
and still have $1500 left over for 10 years of streaming!!!  :)
in all seriousness, it is a wonderful unit...
Delta77
I wouldn’t mind giving this one a try..
http://www.wellsaudio.com/majestic
