Blu Ray player recommendations
0 Members and 1 Guest are viewing this topic. Read 1753 times.
Sparky14
« on: 19 Mar 2020, 04:08 am »
One of ours died, and I haven't really been paying attention to BR players. I kind of figured when one of mine died, then I'd finally get that Oppo I wanted.
OOPS!
So...what's good these days? I did get a 4K UHD TV a couple of years ago, so it needs that. And for me...audio>video. I'm a 2-channel guy, no surround sound system. Mid-priced....$150-$350.
After some interwebbing tonight, I came up with two Yamaha BD-S681 and Sony ubp-x800m2. The Yamaha seems to have an audio edge, the Sony had more bells and whistles and is $80 less.
Any other players I should be considering?
Charles Calkins
Re: Blu Ray player recommendations
« Reply #1 on: 19 Mar 2020, 04:36 am »
     In the past I have looked at a lot of blu ray players. Honestly I couldn't tell any difference in the ones I saw.
     I finally bought a Sony. Good enough for me.
                                                  Cheers
                                                  Charlie
Sparky14
« Reply #2 on: 19 Mar 2020, 05:02 pm »
Thanks Charlie,
My last 3 players have all been Sony, and all have done fine. I appreciate the feedback.
rollo
  • Rollo Audio Consulting -
« Reply #3 on: 19 Mar 2020, 06:10 pm »
                                                  Cheers
                                                  Charlie
  +1 on the Sony. Way good enough.
charles
FireGuy
witchdoctor
« Reply #5 on: 19 Mar 2020, 08:44 pm »
I own a Sony and would recommend it. If you want streaming apps double check which ones come bundled because the apps can differ by player.
Freo-1
« Reply #6 on: 19 Mar 2020, 11:24 pm »
I've both the Sony UDP X-1000ES and the X-1100ES.   Very happy with their performance.  They both support DSEE-HX, which enhances CD/DVD 2 channel playback.
« Reply #7 on: 19 Mar 2020, 11:27 pm »
I have a Sony 4k unit too, love it.
