Alert on 6C33 Bias x Hi-Fi Amps Use
0 Members and 1 Guest are viewing this topic. Read 7761 times.
Re: Alert on 6C33 Bias x Hi-Fi Amps Use
« Reply #20 on: 18 May 2020, 10:45 pm »
What sound improvment I would expect from 600 to 1K Ω ?
« Last Edit: 19 May 2020, 01:37 am by FullRangeMan »
E55l2
« Reply #21 on: 19 May 2020, 11:38 am »
More cleaner and tighter sound. All depends of your speaker ofcourse.
« Reply #22 on: 19 May 2020, 10:22 pm »
Thanks its interesting, I though the amps should delevery less power.
E55l2
« Reply #23 on: 20 May 2020, 07:54 am »
With lower Ra the power of the tube increases but the low frequency power of the transformer decrease because of limitations of the flux inside the transformer.
« Reply #24 on: 20 May 2020, 11:34 pm »
Do you think the 6C42 Ra=60Ω are suited to audio ?
E55l2
« Reply #25 on: 21 May 2020, 09:40 am »
You have any datasheets of this tube?
« Reply #26 on: 21 May 2020, 11:04 pm »
No just this image:
E55l2
« Reply #27 on: 22 May 2020, 06:03 pm »
No just this image:
Sorry, can't help you with that. But if you know all the data, i can make a transformer for that :lol:
« Reply #28 on: 23 May 2020, 12:23 am »
I had never see this tube for sale, my supplier at GSTubes also never had it avaliable. I know it has three cathodes so looks more prone to variance than the 33.
E55l2
« Reply #29 on: 25 May 2020, 06:48 pm »
No data, so it can be a proto type, if you have many this could be intersting to make a amplifier but if you have just 1 or a couple it is better for a museum. Remember, if you have a tube with datasheets then a tranfsormer can be made.
« Reply #30 on: 26 May 2020, 12:06 am »
The 6C42 are a regular military tube to V regulation as the 33, but by some reason it is rare in the audio shops in Russia, maybe it is classified yet.
E55l2
« Reply #31 on: 27 May 2020, 05:56 pm »
So if your supplier has none for sale, and there are no datasheets and they are "regular" military..... what is going on? how did you get it and how many?
And can you make better photo's from the tube?
« Reply #32 on: 27 May 2020, 10:13 pm »
I dont have any 6C42, just get this image from a French guy in YT, but seems other modern big tubes are better and simpler as GU72.
E55l2
« Reply #33 on: 28 May 2020, 08:51 pm »
What you mean with "better and simpler as a GU72" .  I looked at the datasheet of the GU72 and it looks as a remarkable tube. Although  not a triode it could be work fine in triode mode......
« Reply #34 on: 28 May 2020, 11:52 pm »
The 6C42 is a complex tube with 3 cothodes.
We had a member that owned the Gogo Audio brand he made amps with GU72 and GMI11.
E55l2
« Reply #35 on: 31 May 2020, 06:15 am »
Are there any triode mode datasheets of these tubes?
« Reply #36 on: 31 May 2020, 06:29 am »
I think the 6C42 being a 7 pin and big brother from the 33 is a Triode too, not a Tetrode.
E55l2
« Reply #37 on: 31 May 2020, 07:18 pm »
Sorry my mistake, the 6c42 is not so intersting because it's not avaiable.
I mean are there triode mode curves from the gu72? and the gmi 11
E55l2
