Elac Debut Reference 62
0 Members and 1 Guest are viewing this topic. Read 6929 times.
trianglezerius
Re: Elac Debut Reference 62
« Reply #20 on: 3 Apr 2020, 01:48 pm »
They present an easy load though. I run them on a 70wpc amp.
richidoo
« Reply #21 on: 3 Apr 2020, 02:50 pm »
86db sensitivity in a 6" "audiophile" speaker is actually pretty good. At $600 it is excellent. It means the raw woofer is ~89-90.
86dB makes 101dB output with 32W.
Wind Chaser
« Reply #22 on: 3 Apr 2020, 03:10 pm »
I’d like to hear them, last years early show reports were very favourable. Another speaker that intrigues me is the new JBL HDI stand mount. It’s more money but...
opnly bafld
« Reply #23 on: 3 Apr 2020, 03:37 pm »
JBL HDI-1600 $1800/pair
Elac Debut Reference 62 $600/pair
Wind Chaser
« Reply #24 on: 3 Apr 2020, 05:20 pm »
Like I said it’s more money, but it intrigues me and I would expect it to be considerably better than the Elac Reference 62. :D :D
mcmusicman
« Reply #25 on: 4 Apr 2020, 01:08 am »
I am intrigued after reading the review. I have been looking to put together a second system for the bedroom and don't want to go the floor stander route. Want to keep it simple meaning no sub.  With a 44Hz bottom this might fit the bill. I have to admit that I am impressed with my Elac12 subs paired with my Maggies so I have an open mind. It has been a challenge as most bookshelf speakers seem to be >50Hz.  I wonder how they would sound with an hybrid integrated like the Vincent SV500?  Add the DAC and keep it all under 2k? Jazz, Instrumental, smooth evening tunes.
trianglezerius
« Reply #26 on: 4 Apr 2020, 12:13 pm »
Mine are breaking in nicely so far.
Letitroll98
  • Too loud is just right
« Reply #27 on: 4 Apr 2020, 01:38 pm »
It appears trianglezerius has started two threads with exactly the same title and exactly the same subject, one of them being moved into the Enclosures circle by another facilitator.  I know you're excited about your new speakers, however this is a violation of site guidelines.  Therefore I'll merge the two topics.
trianglezerius
« Reply #28 on: 13 Apr 2020, 08:47 pm »
They are finally broke-in and sound like the first generation on steroids. Everything sounds better and bigger. Best $600 I have ever spent in audio.
rollo
  • Rollo Audio Consulting -
« Reply #29 on: 13 Apr 2020, 09:04 pm »
  That is exactly the reason JBL came out with A170. Huge competition going on.
charles
trianglezerius
« Reply #30 on: 13 Apr 2020, 09:21 pm »
I have on loan from a friend the JBL Studio 530's I will be comparing the Elac's to soon.
Wind Chaser
« Reply #31 on: 13 Apr 2020, 09:45 pm »
I considered the DR62 but I feel the need or urge or the compulsion to spend more money. It’s so hard to decide when you have no way of listening to any of the speakers that interest you. But I have to say, I’ve read nothing but good things about the DR62.  :thumb:
« Reply #32 on: 13 Apr 2020, 09:54 pm »
Do you could ask to an admin merge these threads ?
mhconley
Letitroll98
« Reply #34 on: 14 Apr 2020, 07:35 am »
I don't have to ask admin to merge topics, it's on my dashboard, and is already done.
