60 dB Bugle vs. 40 dB Bugle with Lundahl transformers?
0 Members and 1 Guest are viewing this topic. Read 1361 times.
santafefrank
What sort of differences should I expect between a Bugle set to 60 dB of gain vs. a Bugle set to 40 dB used with the Lundahl transformers? Compared to buying different resistors, the transformer route about doubles the price, so I am wondering if it is worth it? I am using a 0.4 mV cartridge, so I need some sort of high gain solution.
Frank.
PS - This is a wonderful forum. I have learned a great deal from reading the back posts.
hagtech
    • http://www.hagtech.com
« Reply #1 on: 17 Feb 2005, 12:29 am »
Probably not worth the cost in step-ups.  Gain is easy with opamps.  Set to 60dB and try it out.  If the noise floor isn't good enough, you can revert to 40dB and try step-ups.
jh :)
