0 Members and 1 Guest are viewing this topic. Read 13275 times.
You people need to try OB servo subs with your planars. Trust me, you will thank me later!
No space or money for OB subs. It was a stretch just to accommodate the LRS in my living room. I’ve heard the GR Research OB subs (paired with Super Minis), and yes, they sound great. That said, pairing Maggies with a good sealed sub isn’t exactly slumming it.
The GR subs definitely offer lots of performance for the buck. They certainly can be used as stands for bookshelf/monitor speakers. That’s how the Super Minis I heard were set up. It might be a challenge putting Maggies on top of them though.
Hsu ULS15 (one or duals).
Sometimes I wonder if I needed subs for my my 1.7s or if I needed subs to treat my room problems. I use a pair of Elac S12EQs with the auto EQ feature. After positioning them asymmetrically in the listening space, getting the delay and shift corrected everything came together nicely. I am not an audio technician, still learning every day but remarkably the mids and treble cleaned up, image space became wider and deeper with much better definition all around. Adding multiple large bass traps and some absorption areas did not hurt a bit. I still scratch my head at how adding bass and adding bass traps helped everything else? I think it has something to do with reducing cancellations & smear. Attack or speed seemed to improve as well.
