Affordable amp or integrated that excels space, depth, soundstage
0 Members and 1 Guest are viewing this topic. Read 7670 times.
witchdoctor
The Powergate's low price is stunning for what you get, no way would I open my wallet for more than $200 smackaroos until I gave this a listen. Remember, Amazon has a 30 day return policy so you can always return it. Here is a link to the powergate thread:
https://www.audiocircle.com/index.php?topic=162664.0
Folsom
Looking for any suggestions or experience as this is what I’m looking for.
Affordable means used or new under $2500.
To use with Audio Physic Virgo or other.
"or other" ? That's not very useful. The APV's take 200w to drive right according to reviews. Other speakers might be happy with 2.
Wind Chaser
based on your preferences for space, depth and soundstage, I can vouch for the 2Cherry and I'm pretty sure that the company has a special running right now that will get you the amp below your $2500 target.
https://www.cherryamp.com/5-channel-amp
+1 furthermore I bet it is at the very least as good as the Devialet. I see far more Devialet‘s come up for resale than the DAC Cherries. Sooooooo....
Freo-1
Highly questionable.  The Devialet owners usually sell in order to upgrade to the latest version.     That, along with there strong sales numbers, compared to niche brands,   are the reasons one sees them show up.
You don't see many of the higher end Devialet devices for sale.  They usually get upgraded instead.
As a tube lover, I have to say that the Cherry amps get tone better than Devialet.  Actually the DAC Cherry/Maraschino amps get tone better than any other digital amp I've heard.
Freo-1
I'm also a fan of tube sound, but the Devialet  (especially in mono) are significantly more accurate sounding.   This is due to the high power, SAM technology, and the integrated DAC setup.
The Devialet is not a digital  amp per se.  It's an analog amp that supplies current via Class D.
The reviews are all very positive,  and compare favorably with 100K setups.
Time for a shootout!  :thumb:
Freo-1
I wonder if one has already been done.    I think maybe the Tone Audio folks have been exposed to both?
avta
Here’s Tone review of the Devialet 140 Pro:   https://www.tonepublications.com/review/the-devialet-expert-pro-140/
rikhav
I would recommend you Karan acoustics integrated amplifier.
It's recently discontinued but see if you can find one used in your budget
witchdoctor
How is $6000 "affordable"? :scratch:
Wind Chaser
Depends on what is in your wallet.
witchdoctor
No, it depends on the OP's budget of <=$2500 :duh:
avta
There were some used Devialet units available within his budget.
IMO the best option is the Cherry STM Streo at $1200
OzarkTom
The STM is great, but what happened to the OP?
mr_bill
I'm out here and reading everything - thanks for all the input so far.  I did contact Tommy too based on the amp recommendations
Letitroll98
  • Too loud is just right
And Tommy is a kick to hang out with as well.  The opposite of the stereotypical audio engineer.
Reynolds853
Those speakers have a low impedance and seem a bit power hungry.  I would look in the Musical Fidelity, McIntosh, Hegel area depending on what your likes are.  Hegel is the cleanest/coolest of the three and the integrated DAC /Streamer makes things very simple.  The McIntosh is the warmest and fullest, maybe.  Musical Fidelity is a good mix of those others and can be found for a song.  I got a M6500 for $2k used and it is holds its own against my buddy's mega-buck McIntosh separates system.  So many good options out there, though.
AvsFan
I second that! Dude is awesome! Who cares what his electronics sound like.  :D
But thankfully they sound sublime.
