ELAC Adante AF-61 Floorstander Loudspeakers Rosewood - demos W/warranty
0 Members and 2 Guests are viewing this topic. Read 24676 times.
William Crane
    • http://cranehometheater.com/
Dynamic performance, immersive and coherent sound, musical bass - requires high current, high power amp such as the ELAC DPA-2. No center channel needed on home theater. Authorized ELAC dealer. Buyer gets deep discounts on ELAC gear, Gallo Acoustics, Analysis-Plus, Supra and Silver Sonic (D.H. Labs) cables for one year. Also discounts on Music Hall, Creek. Epos and Goldring.
Daring design.
The ultimate Adante is a bold loudspeaker that breaks through boundaries and challenges the limitations of traditional designs. Engineered and built to quality standards that exceed every expectation, the AF-61 Floorstander delivers performance that will satisfy the most demanding audiophile. It is a loudspeaker of substance for uncompromising listeners searching for the speaker that does it all, at a price as satisfying as its sound.
Power. Gracefully refined.
After turning the audiophile world on its collective ear with the remarkable Debut and Uni-Fi Series loudspeakers, ELAC undertook the mission of creating one of their most ambitious speakers to date. About it, ELAC’s chief engineer Andrew Jones says, “With Adante, what we’re trying to do is bring excellent value to a new price point.”
Adante will surely redefine your concept of what it is possible for an affordable loudspeaker to achieve. Adante’s advanced design starts with a precision-built cabinet that features Interport-Coupled Cavity bass loading to exploit the highest performance from new active and passive bass drivers. The inherent superiority of this design solution delivers some of the most authoritative, realistic bass around. Complementing Adante’s custom low-frequency drivers is the all-new concentric midrange/tweeter, a natural-sound wonder engineered expressly for the Adante series. To make sure they look as good as they sound, each Adante cabinet features a furniture-grade finish in a choice of gloss white, gloss black or genuine satin walnut veneer. The face of each cabinet is an elegant, bonded-aluminum front baffle for maximum rigidity, contoured to incorporate waveguides that ensure optimum dispersion from each driver.
The Adante AF-61 Floorstanding Tower, represents a “clean sheet” design unique to ELAC, where technical solutions, precision engineering and superior craftsmanship all come together to create a breathtaking trio of loudspeakers that sound—and look—like nothing else in the world. Go ahead and challenge Adante with everything you’ve got. We did. Further proof that ELAC is the life of sound.
It’s all about the enclosure
Hugely complex but with benefits that are immediately audible, an Interport-Coupled Cavity cabinet renders clearly superior performance in the reproduction of low frequencies. The engineering challenges and complicated manufacturing requirements of such a design makes it rare in the world of affordable speakers, but Jones’ pursuit of a new value-to-performance benchmark demanded this no-compromise solution.
Each Adante cabinet is actually multiple enclosures in one. The concentric midrange/tweeter is isolated in its own space within the cabinet, and the woofer complement, comprising an active and passive driver, occupies a divided chamber vented internally with dual ports. In the case of the Center and Floorstanding models, two and three double chambers respectively isolate each woofer pair from the other. Instrumental to the design benefits of an Interport-Coupled Cavity is that the entire enclosure is not externally ported at all, because such external ports will produce noise and other distortion artifacts if the speaker is overdriven.
On the other hand, a coupled-cavity design means that the active driver remains invisible, mounted internally in its own rear box that vents bass energy through dual bass ports to a front box which encloses a larger passive radiator. The piston action of this front-firing passive driver delivers low-frequency information that is tight, tuneful, extended and with greater output capability than a traditional externally-ported enclosure. This Interport-Coupled Cavity cabinet enhances the linearity of the active bass transducer by reducing driver excursions.
Optimized cabinet volumes allow for a crossover network tuned to take advantage of such a design. An internally vented box, with another box in front housing a passive radiator—means that acoustically, the front box becomes a second-order acoustic low pass filter, eliminating the requirement for two orders of electrical network, further reducing driver distortion.
With so much buried inside, what does all this complicated engineering mean for your music? It means clean, distortion-free, natural, accurate, authoritative bass that defies the norm and challenges far more costly competitors.
Two amazing woofers that work together
Fundamental to Adante’s superior performance are two new woofers that deliver extraordinary low frequency performance far superior to less complex driver and cabinet solutions. Engineered specifically to work in concert with the elaborate Interport-Coupled Cavity cabinet design, the first woofer is a 6.5-inch active driver with wideband frequency response. It features an aluminum cone and cast basket assembly with a substantial magnet and voice coil. The aluminum cone is fast, stiff and low in distortion artifacts that otherwise compromise bass realism. Mounted inside the complex cabinet structure, it remains invisible to the eye but its presence is readily apparent to the ear.
Partnering with the active driver is a lightweight 8-inch passive radiator. Front-firing, it is mounted to the bonded-aluminum front baffle of the speaker cabinet and features a stiff aluminum diaphragm and cast basket assembly. Its light weight makes this passive radiator faster and less prone to distortion artifacts than active drivers of similar diameter, so it moves air more quickly, with minimal coloration.
Together, this active/passive combination can handle all the power it takes to deliver crushing low-frequency crescendos with the dynamic realism of a live performance. Each Adante model uses identical concentric midrange/tweeter and low-frequency drivers. The Stand Mount, Center Channel and Floorstanding models employ one, two and three active/passive woofer pairs respectively.
All-new concentric midrange/tweeter
ELAC’s proprietary concentric driver technology has been taken to new levels of performance with a brand-new design that delivers astounding point-source accuracy, linearity, power handling, speed and articulation on virtually all types of music. The large, 5.25-inch diameter midrange cone, made of pure aluminum for maximum rigidity with lowest coloration, features a revised profile and generous 2-inch voice coil that results in greater output level and higher sensitivity than smaller concentric designs. The larger 2-inch voice coil also provides more room for a newly-engineered tweeter to be situated in the center. This soft-dome design uses new fabric material and employs a wide surround that results in improved lower-treble output, lower resonant and crossover frequencies. Additionally, the whole concentric driver chassis is mechanically isolated from the other drivers and the Adante cabinet itself with anti-vibration mountings that eliminate the transmission of vibration throughout the loudspeaker.
Four binding posts for added options
Each Adante model is equipped with a dual set of binding posts. A supplied link allows use of a single pair of speaker cables and only two posts, while dual posts allow the option of bi-wiring with a single amplifier, or choosing bi-amplification with the use of two amplifiers, one for the concentric midrange/tweeter and the other for low-frequency drivers.
Specifications
Speaker type: 3-way, interport-coupled cavity
Tweeter: 1 x 1-inch soft dome, concentrically mounted
Midrange: 1 x 5.25-inch aluminum cone
Woofer: 3 x 6.5-inch aluminum cone, internally mounted
Passive radiator: 3 x 8-inch aluminum cone
Crossover frequency: 200Hz / 2,000 Hz
Frequency range: 39 to 35,000 Hz
Sensitivity: 87dB at 2.83 v/1m
Recommended amplifier power: 50 to 160 wpc
Peak power handling: 160 wpc
Nominal impedance: 6
Binding posts: Dual pair 5-way metal
Magnetic shielding: No
Cabinet finishes: rosewood veneer
Height: 52.34 in / 1329.4 mm (with outrigger plate and spikes)
Width: 9.6 in / 243.7 mm
Depth: 15.67 in / 397.9 mm (with grille)
Weight: 101 lbs. / 45.8 kg
Plus Fedex Freight. They ship in individual double factory boxes, each weighing about 114LBS.
I'm happy to deal locally in the LA, CA area. Paypal + 3% fee. Buyer will pay actual shipping plus insurance for the full purchase price.
MSRP: $4,995 SELL: $2,195
