Industry Circles
Triode Wire Labs
Triode Pete
USB CABLE
USB CABLE
0 Members and 1 Guest are viewing this topic. Read 2777 times.
rollo
Restricted
Rollo Audio Consulting -
USB CABLE
10 Feb 2020, 04:09 pm »
Pete do you make a Data only USB ? Just found out my DAC does not require the 5V power wire. Using a split cable now. If I remove power leg any issues ?
charles
Triode Pete
Facilitator
www.TriodeWireLabs.com
Re: USB CABLE
10 Feb 2020, 08:58 pm »
Charles,
A "Data-only" USB cable is available custom ordered only... I do have one in-stock at this time.
Try removing the power leg on your Innuos Music Server. If your Aqua DAC doesn't need the 5V "trigger", it should work fine...
Pete
Last Edit: 11 Feb 2020, 02:35 am by Triode Pete
JackD
Re: USB CABLE
Reply #2 on:
11 Feb 2020, 02:31 am »
When I asked Christian at Aqua that question a couple of months ago he told me it did need it. As a result I bought the Discrete and it sounds great to my ears.
rollo
Restricted
Re: USB CABLE
Reply #3 on:
11 Feb 2020, 04:41 pm »
Jack, I'm using the DAC with latest upgrade to USB and I2S. 5V leg Not require for USB for Formula xHD. Thanks Pete will give it a try.
charles
Last Edit: 11 Feb 2020, 06:41 pm by rollo
rollo
Restricted
Re: USB CABLE
Reply #4 on:
14 Feb 2020, 08:55 pm »
OK. Removed power leg. OMGoodness. Cleaner sound which is hard to believe but so. If ones DAC has the 5V power built in your gonna be a happy camper.
charles
Industry Circles
Triode Wire Labs
Triode Pete
USB CABLE
