X3 Owners' thread
Desertpilot
  • Retired
Re: X3 Owners' thread
« Reply #120 on: 16 Sep 2021, 10:55 pm »
I had a little scare today.  As you know, I purchased a third X3 for center channel duties.  Today, I was playing a Jazz album (CHRIS BOTTI, NIGHT SESSIONS in 5.1 multichannel, DSD 64).  Lots of bass.  As I was listening, I thought the center channel was not producing enough bass.  I felt the rear of the bass driver on all three speakers.  The left and right speakers were pulsing away.  But, the center channel sub was barely moving.  My heart dropped.  I thought I got a defective speaker.  So, I swapped the left and center channel speaker wires.  Whew!  Center channel sub was rockin' and rollin'.  Left channel sub was quiet.  Must be the way the music was mixed.
Marcus
« Reply #121 on: 17 Sep 2021, 02:27 am »
Marcus
Is it hooked to a receiver or an HT pre-pro?  If so, check to make sure the center channel is set to "Full Range".
Desertpilot
  • Retired
« Reply #122 on: 17 Sep 2021, 12:41 pm »
No pre/pro or receiver.  Music from DAC direct to my amplifier.  It is all good now that I checked and verified sub is working properly.
Marcus
« Reply #123 on: 28 Oct 2021, 06:41 pm »
Just got notified, my X3's are being delivered on Monday - woot!!
morganc
« Reply #124 on: 28 Oct 2021, 07:30 pm »
Congrats!
Daryl Zero
« Reply #125 on: 28 Oct 2021, 08:36 pm »
Yes, congrats.
Desertpilot
  • Retired
« Reply #126 on: 1 Nov 2021, 03:04 am »
Tyson.  Awesome news.  You are going to love them!
Marcus
doggie
« Reply #127 on: 29 May 2024, 10:25 am »
Can someone who has a pair of X3's please take a look at the Hypex plate amp and tell me the model number.
It is probably something like FA501
Thanks a lot!
lazbisme
« Reply #128 on: 29 May 2024, 10:57 pm »
mine is FA251  but I understand there were two different ones used depending on inventory
morganc
« Reply #129 on: 30 May 2024, 06:08 am »
Mine are the FA251 also.
doggie
« Reply #130 on: 30 May 2024, 01:43 pm »
Thanks for the replies. It is appreciated. According to their website Hypex does still carry the FA501.
For someone wanting to replace their problem X3/X5 plate amp this is good news. Also according to David Whitt, Clayton still has the ability and willingness to update the onboard DSP so the amp will integrate with our X3/X5 speakers.
samuel6363
« Reply #131 on: 15 Jul 2025, 06:38 pm »
Hello All!
I am picking up a pair of X3 Premium tomorrow. I'm excited! Can anyone tell me what is different between the regular X3's and the X3 Premium? Also, does anyone know if the powered woofer is a servo controlled sub/amp?
samuel6363
« Reply #132 on: 15 Jul 2025, 06:44 pm »
Audiophiles... I am planning on using a Decware Zen Triode 25th Anniversary model amplifier with my new Spatial Audio X3's. At 97db efficient and the on-board powered woofer, I'm hoping this amp will work well. If not I have other power amps that will power these without issue.
My question is this... have any of you used a Decware Zen Triode amp at only 2.3 watts to drive the X3's? If so, what was your experience?
My room is a small 13'X10' guest bedroom with some acoustic treatment, so I don't need much power.
Looking forward to any information you may offer.
Sam
Jprod
« Reply #133 on: 26 Jul 2025, 01:45 pm »
Hello.  I have used a Tori jr at 20wpc with my x5s.  While decent they really opened  up when I tried instead the ps audio m1200 Monoblocks.  Better sound at low volumes , more detail
, more 3d.  Just better in every way except maybe in the vocal midrange.
Don’t think a little over 2 watts will cut it but that depends on what you listen to , room size etc.
Maybe in your 13x10 room it will be enough.
mrotino332
« Reply #134 on: 29 Jul 2025, 12:58 pm »
I agree with Jprod.  My 30 watt/channel amps were plenty for my X5s but moving up to 200 w/channel just seemed to be an improvement especially at lower volumes.  I also don't believe 2 watts will be enough.
I believe the premium X3/X5 just had the latest crossover parts which were the Ven Haus Odams.  The original models had Clarity cap CSAs.  The drivers are the same.
thestatman
« Reply #135 on: 24 Sep 2025, 08:36 am »
Am using my X3 special edition (500w plate amp, special giant cap for tweeter, same as Don Sachs one and Clayton's personal one) with the Aries Cerat Genus integrated amp, all 25 watts of it.   Amp blows the roof off the speakers but then again it is a 67kg Class A SET amp, a rare beast indeed.   Bass goes flat to 30Hz at least on my test tones CD and SPL meter, bass setting is 1 o'clock on the amp faceplate, anymore and it is both overpoweringly elevated and the amp clipping light comes on so I must be dumping close to 500 watts on peaks into the woofer at one o'clock setting.   I do listen pretty loud, typically 95-100dB peaks, get a bit of tinnitus at the end of a rock listening session but hey its worth it for that visceral feeling that I'm 25 again.   Wouldn't choose to change these out even though my first love is Stats (clearly I'm polygamous).
