Triode DAC to USB C cable?
0 Members and 1 Guest are viewing this topic. Read 2520 times.
robert bullock
« on: 7 Feb 2020, 05:06 pm »
Hi, I wrote Triode directly a couple days ago but haven't heard back, so I'm trying here now: I have a Vinnie Rossi Lio amp and have heard great things from Vinnie (and others) about Triode cables.  I'm interested in getting a USB cable to connect the onboard DAC directly to my Macbook Pro (2019), which has only USB C ports. (Vinnie, at one point at least, says the direct connection works very well with the DAC 2 upgrade, which I'm about to order.)  Does Triode make such a cable? I don't see anything on the website but you never know.  It seems very few high quality cable makers make USB C cables as yet.  Would I be better off buying, say, a Carbon or Diamond from Audioquest, which does offer that option?  Or, using a Triode (or something else) with a A to C dongle (I have an Audioquest one already)?  I don't like the idea of adding yet more stuff between the server and the DAC, but does it make a difference in terms of audio quality?  Btw the speakers for the system are Reference 3a mm de capo BE, which I've been very happy with.  Thank you very much!
rollo
  • Rollo Audio Consulting -
Re: Triode DAC to USB C cable?
« Reply #1 on: 7 Feb 2020, 05:12 pm »
  That would work well. I believe TWL is at the Florida show now.
charles
Triode Pete
« Reply #2 on: 8 Feb 2020, 03:11 pm »
Hello Robert,
I just double-checked my inbox and did not receive your email.
I do not currently fabricate an USB-C cable. The connections, being so tiny, would require a micro-welder...
Currently, having fun in Tampa at FLAX!
Pete
