StylusTimer
0 Members and 1 Guest are viewing this topic. Read 785 times.
xsb7244
StylusTimer
« on: 6 Feb 2020, 12:55 am »
StylusTimer created by Don Lindich.  This tracks stylus usage.
https://stylustimer.com
Elizabeth
Re: StylusTimer
« Reply #1 on: 7 Feb 2020, 02:24 am »
I use a golf clicker. $6.99 lasts forever, does NOT need a battery...
I click once per side... easy. I own two clickers. They can sit for years.. or get used every day.
They are already pretty old.
This device with a link reminds me of a digital weigt scale for the cartridge.. I bought one. it worked for a few days. Then I discovered I had to remove the battery or it would be dead.. next time. Then it just stopped working.
The Shure mechanical gauge I have is at least fifty years old. and still works just fine.
Re: StylusTimer
« Reply #2 on: 7 Feb 2020, 02:44 am »
Nice, it even may be used with tubes.
This current anemic modern crop of tubes will not reach 9000 hours.
SET Man
Re: StylusTimer
« Reply #3 on: 8 Feb 2020, 02:13 am »
Hey!
   That's not bad at all. Well, it is just $20 and not overpriced as an "Audiophile" labeled accessories.
   Anyway, I've been using this hand tally counter to track the hours of my KR Audio 842VHD tubes for some years now. I also have another one to track the 845B tubes in my other SET amp.
   But that digital counter would be more accurate for sure, I might get one :D
Buddy
