KT88 bias level..?
0 Members and 1 Guest are viewing this topic. Read 3900 times.
Delta77
KT88 bias level..?
« on: 5 Feb 2020, 12:47 am »
I just installed some Sophia Electric KT88’s in my Decware (Zen Mystery Amp) and they want to bias much higher than the EL34’s I was using..
The KT88’s want bias around 70-80
The EL34’s biased around 20-30
Does this sound about right..??
Is there anything to worry about running around 80..??
Re: KT88 bias level..?
« Reply #1 on: 5 Feb 2020, 01:19 am »
If this amp are auto-bias as the other small ones its OK.
The owner manual say what?
OBS.: Looking the Decware site I see this amp not auto-bias, you will havr to read the manual or ask at the Decware Forum.
Delta77
« Reply #2 on: 5 Feb 2020, 01:37 am »
I got it to bias around 66mA ,
Seems a little safer..
 I will keep an eye on the transformers temperature..
Freo-1
« Reply #3 on: 5 Feb 2020, 03:27 am »
Yes, the KT-88 does bias higher than the EL-34.  I would tend to think that 70 ma or less for the KT-88 should be OK.
« Reply #4 on: 5 Feb 2020, 03:49 am »
The inspire Fire Bottle bias at 23V 63mA for the KT88 to 11W.
Francois G
« Reply #5 on: 31 Mar 2020, 06:56 pm »
As previously suggested, check the manual. 80ma per KT88 sounds high. Are you running now @around 60ma per tube? Any over-heating of the power or output transformers evident?
Francois G
« Reply #6 on: 31 Mar 2020, 08:28 pm »
I spent a few minute on the DECware website to see if I could get any helpful information.
This is what I found:
INPUT TUBE CHOICES: 6N23P, 6922, 6N1P, 6DJ8, 7DJ8
OUTPUT TUBE CHOICES: EL34, 6CA7, KT77, KT66, 7027, 5881, 6L6G
IDLE CURRENT: 40~60 MILS PER OUTPUT TUBE - ADJUSTABLE
HIGH B+ VOLTAGE: 410 VDC WITH LOAD
Notice that there is no mention of KT88 as output tube? Notice that the maximum allowable idle current is 60 ma per output tube. I believe these are set by the designer based on the power transformer used. Could be conservative, but since the amp is quite expensive, I would tend to stick to the “approved output tubes, and idle currents”.
