Cheap network upgrades
« on: 21 Jan 2020, 10:23 pm »
Any tricks to have a little more bandwidth on a budget?
Peter J
  • Hmmmm
Re: Cheap network upgrades
« Reply #1 on: 21 Jan 2020, 10:56 pm »
The first thing to do is see if you're getting what you're paying for by doing speed test.
https://www.speedtest.net/
Let's see where that takes us and go from there.
Generally speaking wired connections are going to be faster, but it depends on the device.
What do you want to achieve?
« Reply #2 on: 21 Jan 2020, 11:06 pm »
From what I figure, I need a better switch to increase internal transfer speeds. I could use a link aggregation to increase router to switch bandwidth/speed. Is there a switch that is unmanaged but has link aggregation?
Peter J
  • Hmmmm
« Reply #3 on: 21 Jan 2020, 11:13 pm »
 What problem are you trying to solve?
« Reply #4 on: 21 Jan 2020, 11:18 pm »
Mainly transfer speeds between PCs.
Peter J
  • Hmmmm
« Reply #5 on: 21 Jan 2020, 11:29 pm »
As to link aggregation, it's the first I've heard of it, so Google to the rescue, but I don't have an answer to specific product availability.
 I assume you're using gigabit router, switches and network interfaces within computers. I'm not an expert, but I've never had to consider transfer speeds on a wired network in what little network implementation I've done. It just didn't present a problem.
How does the problem manifest itself?
nlitworld
« Reply #6 on: 22 Jan 2020, 03:23 am »
The best things for internal network pc transfers comes down to having a decent router or 10/100/1000 switch that is hardwired to both pc or stream box and also decent hard drives where data is stored. Solid state hard drives and cat 6 network cables are your friends!
davidldl
« Reply #7 on: 22 Jan 2020, 04:31 am »
10 gigabit network for home.  2 cards and 1 cable.
(intro)
https://www.youtube.com/watch?v=MgNpI6VAAhI
you can google look at sfsp+ and qsfp+ for home use.
if you want a real switch for 10gb.
https://www.youtube.com/watch?v=MDiiHN0MPdA
David
