0 Members and 1 Guest are viewing this topic. Read 5051 times.
If the OP is happy with his Class A (presumably) SS amp, it's possible he'd get the smoothness he's after and not loose bandwidth and woofer control switching to a high output impedance SET amplifier, by inserting a Lampizator tube dac as a source. I've heard a couple horn based systems transformed by the addition of a Lampi.
doesn't stream so still requires a computer
The Node can be found here: https://www.audiosciencereview.com/forum/index.php?threads/review-and-measurements-of-bluesound-node-2i-streamer.6631/My impression is that there is room for improvement.My opinion is that a DAC should be as neutral as possible, you want to hear the recording, not the DAC.Likewise there ain't such thing as matching DAC with a horn.A good neutral one with a plethora of DSP options: RME ADI-2 DAC
I don't buy all the talk about no reason to buy a DAC over $1K. I haven't heard a DAC under $1K that sounds better (more depth, texture, tone, detail, air, transparency and sound stage better than the DAC's that I have heard or had in my system.I have had the Exogal Comet, Chord Hugo, PSA Direct stream, my current Luxman DA-06, Marantz NA11s1, Cary TS200 and have heard an Exasound, T+A DAC8 ( a truly awesome DAC), AVA Hybrid Tube DAC, Lampizator Lite, Bryston, W4S DSDse with femto upgrade, Bricasti M1 to name a few.Now if the rest of your system is not up to snuff including usb cable you may not hear dramatic differences. Keep buying sub $1K DAC's and be stuck in mediocrity. Good to very good sound but not great. My system with a BAT VK51se preamp, Pass Labs X250 amp will show you the weaknesses on any DAC.
That is my experience as well. In most cases you get what you pay for. My current one is a W4S 2V2 SE.
Hello, I have made strides, I have a streamer....I bought a Chinese one first and now have a Bluesound Node 2i. Although it gets generally good reviews, the opinions on the DAC vary greatly. So I looked on Audiogon and ebay. Too many brands. I have never owned a DAC and don't have any stores to listen. I have Klipsch DIY speakers that sound quite good but am wondering what I would get with a separate DAC I feel a discussion about the proper match with the horns would help. I don't want to spend over $1K. Less is better. I realize opinions are all over the place but it would give me somewhere to start. PS, I am not using a preamp and have a Class A Schiit Aegir which works well with the horn speakers. Thank you for the help. Is it the Border patrol that has a tube and would that help? Might be over the $$ amount. Here I go again.
I think amp/dac synergy is more important than just dac.
amp/dac synergy
