max length of DC power cables?
kenreau
« on: 18 Jan 2020, 05:51 pm »
Continuing on with my intended replacement of the cheesy smps for my fiber optic to Ethernet convertor.  f
I realized I have a HD Plex power supply with a spare 12Vdc outlet that could supply this cable convertor.  The convertor needs 12Vdc at 2Amps.
The only concern is the two locations are close to 45 lineal feet apart.  I can custom fabricate a 45' DC power cable feed, but was concerned if that distance may cause issues with resistance, or some other power loss (I'm not an EE).   :scratch:
Thanks in advance
Kenreau
Speedskater
  • Kevin
Re: max length of DC power cables?
« Reply #1 on: 18 Jan 2020, 06:34 pm »
I would find another solution.
rlee8394
« Reply #2 on: 18 Jan 2020, 07:02 pm »
The smaller the wire gauge (thicker) the less resistance for a given length. Consider that house wiring of 12AWG can handle 120 volts AC at 15 amps, you should be fine with about 16 AWG, maybe even 18 or 20 AWG.
-Ron
Speedskater
  • Kevin
« Reply #3 on: 18 Jan 2020, 07:23 pm »
On second thought.
It's just for a " Ethernet convertor".
That will work just fine. Take an AC extension cord and cut the plugs off it.
kenreau
« Reply #4 on: 18 Jan 2020, 10:36 pm »
Awesome, I'll try it out.
Thanks for the quick replies.
Kenreau
