**SOLD** Audioquest Wild Blue Yonder - 72v DBS - 1m RCA interconnects
0 Members and 1 Guest are viewing this topic. Read 534 times.
pepperinca
Offered here is one of the best Audioquest cables available:
The Audioquest Wild Blue Yonder Interconnect in a 1 meter length.
With a MSRP of $4500, Wild Blue Yonder is Audioquest's 2nd most expensive cable and depending on ones' system, is equal in performance to their WEL Signature. From what I've gathered, the Wild Blue Yonder Interconnect is a bit more neutral and balanced than the WEL Signature and which cable one uses is both system and component dependent.
Cable is in excellent condition and DBS packs are fully operational.
I do not have the original box, but they will be packed and shipped with care.
Sell for $1750 shipped to CONUS
Info from the Audioquest website:
"SOLID 100% PERFECT-SURFACE SILVER CONDUCTORS (PSS): Perfect-Surface Technology applied to extreme-purity silver provides unprecedented clarity and dynamic contrast. Solid conductors prevent strand interaction, a major source of cable distortion. Extremely high-purity Perfect-Surface Silver minimizes distortion caused by the grain boundaries that exist within any metal conductor, nearly eliminating harshness and greatly increasing clarity compared to OFHC, OCC, 8N and other coppers.
FEP AIR-TUBE INSULATION (FEP is a Fluoro-Polymer): Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy (loss). Some of this energy is stored and then later released as distortion. All of Wild Blue Yonder’s conductors use Air-Tube insulation because air absorbs next to no energy, and FEP is the best extrudable solid insulation and absorbs less energy than other materials. The FEP Air-Tubes used in Wild Blue Yonder have almost nothing but air around the solid PSS conductors.
DIELECTRIC-BIAS SYSTEM (DBS, US Pat #s 7,126,055 & 7,872,195 B1): All insulation slows down the signal on the conductor inside. When insulation is unbiased, it slows down parts of the signal differently, a big problem for very time-sensitive multi-octave audio. AudioQuest’s DBS creates a strong, stable electrostatic field which saturates and polarizes (organizes) the molecules of the insulation. This minimizes both energy storage in the insulation and the multiple nonlinear time-delays that occur. Sound appears from a surprisingly black background with unexpected detail and dynamic contrast. The DBS battery packs will last for years. A test button and LED allow for the occasional battery check.
CARBON-BASED 7-LAYER NOISE-DISSIPATION SYSTEM (NDS): 100% shield coverage is easy. Preventing captured RF Interference from modulating the equipment’s ground reference requires AQ’s Noise-Dissipation System. Metal and Carbon-Loaded synthetics prevent most RFI from reaching the equipment’s ground plane.
TRIPLE-BALANCED GEOMETRY: The three conductors in “Triple-Balanced” Wild Blue Yonder cables ensure that whether prepared with RCA or XLR plugs, the positive and negative signals have equally low-distortion conducting paths. The 100% coverage shield is never used as an inferior conductor."
« Last Edit: 27 Jan 2020, 11:26 pm by pepperinca »
