DSP Technical Educational Resources
0 Members and 1 Guest are viewing this topic. Read 12828 times.
Occam
« on: 11 Feb 2005, 02:31 pm »
There are a number of concepts that need to be clearly understood to facilitate discussion of audio dsp. Concepts such as the goals of linear or minimum phase and how they can be implemented. Specifically, FIR does NOT imply a linear phase result, and likewise, IIR does NOT imply a minimum phase result. It all depends on the implementation and what preceeds it.....
http://ccrma.stanford.edu/~jos/filters/
This is Stanford's
INTRODUCTION TO DIGITAL FILTERS WITH AUDIO APPLICATIONS
Ideally, one should have a vauge recall of their 200 level Linear Algebra course, and a familiarity with concepts of Abstract Algebra. (luckily, my youngest son will occasionally dain to explain such things to me).
http://www.dspguru.com/
Is a broad ranging site with excellent tutorials and FAQs, among many other things
the hompage of the much referred to BruteFir, and the lesser known AlmusVCU -
http://www.ludd.luth.se/~torger/
Courtesy of Davey, I'm adding this resource -
http://www.dspguide.com/
Which is a site hosting -
The Scientist and Engineer's Guide to Digital Signal Processing
by Steven W. Smith, Ph.D.
You can download the whole book....
Again, while this offers far more expository discussion, a relatively sophisticated quantitative understanding is called for.
Courtesy of woodsyi, an excellent site -
http://www.dspdimension.com/start.html
Now, after I've lambasted vendor's 'whitepapers', courtesy of Eico1 -
http://www.meridian-audio.com/w_paper/Room_Correction_scr.pdf
This paper represents Meridian's, as well as Rives', approach to room correction.
With all these links, be sure to check their own links.
Anyone with additional resources they'd like added to this 'sticky', please PM me with the reference.
