When will you switch to current production gear?
I'd imagine when there is a reason to ....jay
Danny mentioned he might be picking up the Elekit Japan 300b amp, the current version of the one I brought along for my demo.
Yeah, I don’t get it, Jason. As long as it measures great, it shouldn’t matter should it?
Yes, but less than with box speakers.
And I am building out some of the Folsom high powered chip amps.
If I ever find anything that sounds better I'll use it.
So you're saying that all your customers who do not use what you do (which isn't available) will not get the same result?
That is true for every piece of equipment sold. And for every room that it goes in.
Tyson, did the Dodd preamp feed both the First Watt and 300b amps? I assume yes for the First Watt, but does the Elekit have its own volume control?
You're missing my point though. He's using gear that you can't buy new...not even an option. Just strange for a manufacturer to do that. Whatevs
