Hot water heat
golddustpeak
Hot water heat
« on: 2 Jan 2020, 01:45 pm »
We have hot water hearing registers just above the floor along our walls.
I'm wondering how can I place traps in the corners of the room?
TNX
jriggy
Re: Hot water heat
« Reply #1 on: 2 Jan 2020, 03:18 pm »
Make a short open frame platform that positions the traps over the heaters??
I once had an obstruction in a corner so I just put the tri-trap up on small blocks to rais them over the protrusion.
Be inventive.
jtcf
Re: Hot water heat
« Reply #2 on: 2 Jan 2020, 05:04 pm »
If you're using the 2x4 bass traps they hang on the wall with picture hooks so you can position them as high as you'd like.
twitch54
Re: Hot water heat
« Reply #3 on: 2 Jan 2020, 07:22 pm »
TNX
I have the same, simply position the corner traps on top of the baseboard heating in the corner, works perfectly
Strut
Re: Hot water heat
« Reply #4 on: 2 Jan 2020, 10:36 pm »
I had an outlet that was too close to the corner and prevented me from setting a trap on the floor.   I ended up getting a 4' piece of 6" diameter PVC pipe, sawing it in half and elevating the two front corner traps 24".  Took all of 10 minutes.  Just make sure to get a perfectly flat, even cut.
