Amber 3 Low Volume DSD Files Roon?
0 Members and 1 Guest are viewing this topic. Read 2253 times.
khill
« on: 24 Dec 2019, 03:57 am »
Just received my Amber 3 and I can’t seem figure out why my DSD files have hardly any volume? Setup is USB to Aries Mini with Roon as playback engine. Any suggestions? I emailed Lukasz but crickets!?! Probably busy with holidays.
Toob_Boob
Re: Amber 3 Low Volume DSD Files Roon?
« Reply #1 on: 24 Dec 2019, 07:04 am »
DSD is generally 6dB quieter than the same recording in native PCM. This is to prevent overload in the sigma-delta modulator. Typically you can boost the playback (or DSD to PCM conversion) by 6dB, especially with classical recordings, but there are DSD recordings mastered without 6dB of headroom.
khill
« Reply #2 on: 24 Dec 2019, 01:40 pm »
FIXED! Set “Volume Leveling” in Roon settings for my Aries Mini to “Auto” and BOOM, all is good!
 :thumb:
