0 Members and 1 Guest are viewing this topic. Read 5717 times.
Believe it or not, I ended up using ( small ) sleeping bags which are about 4' in length...I use them over my Devore Silveback's . Protects them from Cold or Heat , also protects them is they get knocked over . I chose a nice solid color sleeping bag and would not be without them......
We do not recommend furniture polishes or waxes. These will not penetrate the topcoat and will never get to the wood itself anyway. So there is no advantage to using them. They will only attract dust faster.Here at the shop, we use Meguiar's Quick Detailer, available at any auto parts store. Spay a little on a soft, lint-free cloth and wipe down the surface. This is used to wipe down cars and works great on lacquer finishes. It does not leave any residue to attract dust.- Jim
I think the OP needs protection from his cat jumping up onto the speaker top. I’m thinking perhaps some glass cut to size (the thicker, the better). Have the glass shop flame polish the edge.Place on top of the speakers separated by plenty of heavy felt pads adhered to the glass. Perhaps add a rubber pad or two. Hopefully this will keep the glass from sliding when kitty lands or exits. Easily removable when you’re listening.Good luck!JD
Well, if the look of the finish doesn't have to be wood, Jim could probably build them either with a protective coating or some type of non-scratch surface.
Another idea: Purchase a small thin rug pad made with maximum grip strength in mind. Use contact cement to glue two sheets of the material together, felt face to felt face. Cut pads from the resulting sandwich. You now have a presumably "finish safe" material with a lot of grip strength on both sides to resist skidding. Note the info at the bottom of the page about checking whether to use natural rubber or vinyl with different wood finishes. I have purchased multiple pads from this business for use with our oriental rugs and they are very good quality. https://www.rugpadusa.com/collections/for-hardwood-floors/products/rugproBy the way, I have heard reports that Sorbothane is terrible about leaving marks in finishes, perform due diligence investigating.
Get rid of the cats or don't let them in the listening room lol .
@Photon46, it looks like this may be perfect and no gluing needed:https://www.rugpadusa.com/collections/natural-rubber/products/super-lock-natural
