0 Members and 1 Guest are viewing this topic. Read 36772 times.
Oh no...a parts express amp & $400 sub:(What is the world coming to.......-Ed
The world is coming to be a better place for audiophiles. That's a great way to go. The amps are good and with high quality subs like VMPS you have great bass that's easy to hook up and use. Note this is the best and most expensive amp Parts Express sells and is well designed.
Has anyone looked at Outlaw's M-200? It's also a class G (AB with downconverting power supply), it's cheaper, it has auto-shutoff, and it seems to have *much* better numbers all around. Where it falls down is in wattage - 300W into 4 ohms. quote]Doesn't have the crossover either, so it's not a real good deal if one needs the crossover.Russ
Nothing intellectual about B's Bass ..
Has anyone looked at Outlaw's M-200? It's also a class G (AB with downconverting power supply), it's cheaper, it has auto-shutoff, and it seems to have *much* better numbers all around. Where it falls down is in wattage - 300W into 4 ohms. Now I realize that the human ear isn't so fussy about THD at 20Hz, and that, subjectively, more power means more impact - and stuff below 30Hz is all about impact. Few people buy subs, I'm guessing, to have purely polite, dry, restrained deep bass experiences. But I w ...
I just purchased one of the 1000 w amps from VMPS and I'm pleasantly surprised. I was using on of the 300 watt channels from my Cinenova 3, which I liked, but I wanted the convenience of being able to connect and separately control the input from my MiniMax preamp for stereo and my sub LFE from my surround sound receiver. I'm most impressed that the bass is tighter and has more punch than with the Cinenova. The impact from a kick drum has more dynamic slam than before. The deep sound of an acoustic ...
John,Can you clarify a couple of points?1. How many amps are needed for a pair of speakers, one or two?2. Do you need an OXO to use them?3. Can they be used with the RM1? (I run with a tube amp, an have longed for a decent bass amp for a while!)John K.
What about Gallos bass amp? Would that work well?
