0 Members and 1 Guest are viewing this topic. Read 8365 times.
John,> The first is the ceiling louvers, which of course are "broadband", but depending on construction would have the potential of disturbing/trapping bass wave travel. <Wow, nice room! But I can't tell if the devices on the ceiling are absorbers or diffusors. Or maybe they're both?> The second shows the half moon columns that too disturb low frequency flow (at least the look like they would) <The curved deflector on the front wall will affect only higher frequencies. It would have to be much larger/deeper to do much at the low end. And the tube traps are of course absorbers. They do claim some deflection, but that too is at higher frequencies only. ...
I don't know much about anything, which is why I included the disclaimer at the beginning of my post. I did look at the ceiling of that room. You can read about the construction of that room in the link that I included. What seems to take up a lot of space in that ceiling is the absorption...
"Obstructive" devices, otherwise known as diffraction, have little to do with redirection of flow of "bass energy," and it's easy to imagine a room with concrete floors, walls, and ceilings treated with all sorts of foam and other fancy "obstructive" devices with little or no absorption at low frequencies. What will happen? The room will be very boomy.
Again, I suggest constructing a room with concrete floor, walls, and ceiling. Cover all the surfaces of the room with that egg carton stuff. The room will still be boomy.
John,I bet those are both reflective (diffusive) and absorptive. I would think that diffusion is probably related to frequency/wavelength -- you need smaller diffusive elements for higher frequency/smaller wavelength. Additionally, if you can diffuse high frequency signals, you can diffuse low frequency signals. By the way, is that anechoic chamber for sound or for radio frequency waves?
Well,Somebody fly us out there so we can find out! It's an interesting design, although the WAF is low -- very low. Heck, even Ethan's products are low on WAF. That room might be in the negative territory!
I think that the sound waves reach the corners because there is nothing between the point source and the corner, not because they slide along the boundaries.
I thought that megaphones and horns had to do changes in impedance between mouthpiece and outlet, that symphony orchestra shells had to do with reflections, and that waveguides controlled dispersion. Perhaps you can point me to the name of the principle or law or tenet that governs how bass reaches a boundary and travel parallel to that surface. Are there particular frequencies above which this does not occur? Do frequencies above, say, 200 Hz also get "funneled" into corners? Is there, perhaps, some equation of frequency that predicts what portion is reflected at the angle of incidence and which portion is redirected to travel parallel along the boundary? As I wrote, I am not very knowledgeable about these matters, particularly because I only understand the most elementary physics. I would love to learn more. Thanks! ...
My understanding was that increased sound pressure levels at boundaries has to do with reflections and the creation of modes, not because sound is "directed" or "collected."
You wrote "The energy traveling along each wall for example is somewhat "funneled" into the corners." I misinterpreted this to mean that the bass was somehow attracted to the corners. I actually don't know how to interpret this at all. My apologies.
John, I think you're seriously confusing waves and fluids. ...
Let's discuss your sink experiment. Your sink experiment uses water, which is a fluid. Can you make a standing wave by dipping your finger? No. Does this mean that standing waves do not exist because you can't create them with your sink experiment? No. Your sink experiment doesn't "prove" anything about sound. It's an analogy and a flawed one at that. Sound is not a fluid. A speaker cone does not move only once.
Take, for example, a 10x26x17 (HxWxD)room. Place a floorstanding subwoofer in one corner playing pink noise with bandwidth containing frequencies from 20 to 120 Hz. Lie down in the opposite corner. What do you hear? At certain frequencies is the bass boomy, and if so, what? Take your premise that "bass energy" is "directed" or "funneled" or "collected" into the corner, or that bass somehow is "directed/reflected" along the boundaries to the corner. Can you make any predictions about which frequencies will be boomy? Bass at ALL frequencies should be collect in corners, but this is simply not the case. Corners sound boomy because certain frequencies are louder than others. If all frequencies were louder, then the bass would be smooth but louder. Which frequencies, based on your premise? Impossible to predict, as far as I can tell.
Go to the center of the room. What happens? According to you, bass should be evenly reproduced at all frequencies because it's not "collected" or "funneled" into the center, right?
You write "The physics of force containment and flow is very similar in a lot of areas," but sound does not flow, really. Sound is not a liquid that comes out of the speaker, hits the wall, and is directed toward the corner. I have no idea what force containment is. What does "force containment" (try Googling it and see what you get) have to do with sound?
You write "My assertion that sound waves travel along boundaries is supported by many things (Megaphones, Horns, Symphony Orhestra shells, wave guides, etc) so this is a tenet of acoustics," yet you are unable to "align the answers" to my questions about these particular things. Why is that?
You write "A funnel is a device that allows you to fill a small opening from a wider, larger one. It would for example allow your to fill a "bottle" with a "bucket". It takes a larger stream or load and "funnels" it to a more focused and smaller area. It collects from a larger area and directs to a smaller." A funnel works on FLUIDS. What does a funnel have to do with sound? A megaphone and a horn place the sound source at the smaller aperture. What do you think happens if you have a reverse horn, which would resemble a funnel?
Am I the only person here with some fundamental misunderstanding of basic physics and acoustics? If so, I'll have to go to my parents' house and dig up my old copies of Hans Ohanian's "Physics" textbook and F Alton Everest's "Master Handbook of Acoustics" to see if my memory is so askew.
I should add a few notes:1. You're right. Air and water are fluids. However, air is a gas, and water is a liquid.
2. Sound pressure levels are a measure of the intensity of periodic pressure fluctuations. The periodicity depends on the frequency of sound. Sound therefore depends on alternating high and low pressure regions travelling through the medium under discussion (here, air). You wrote that 'Sound waves are measured in frequency and pressure. To have sound you must have frequency and pressure." This is not quite correct. Sound is measured in frequency and SPLs. To have sound, you must have periodic fluctuations in pressure at a certain frequency.
3. The energy of a wave can be measured in terms of power, or energy transferred per unit time. This is a function of the speed, frequency, and amplitude of the wave, as well as physical properties of the medium under consideration. You wrote that "The bullies of the sound world are Low Frequencies. The have the most energy/force." This isn't quite correct. If speed and amplitude are equal, then high frequency sound actually has more energy than low frequency sound.
Well, unfortunately, I may not have much opportunity to post for the rest of the weekend. If other folks believe that bass is "funneled" into corners, than cue balls are "directed/reflected" towards pockets instead of following basic laws of physics, and sound waves travel parallel to a boundary when they encounter it, then there's not much I can say. I'm sure you'll enjoy the acoustics in your room.
You all might find this to be of some relevance to the above discussion:www.acousticshut.fi/asf/bnam04/webprosari/papers/o25.pdf(Youngho, I think you misunderstood me, I was suggesting obstructions would only break up axial modes if the dimensions were some appreciable fraction of the wavelength. Jumped into the thread w/o looking at all the links).If I am understanding the above reference, when it comes to low frequencies, and interactions with walls, the wall tends to behave as a diffuser. "Bank shot" physics are most evident with high wave numbers.Cheers,John
