FS: Spatial Audio Hologram M4 Turbo-S (Black) Open Baffle Speaker Pair
0 Members and 1 Guest are viewing this topic. Read 1337 times.
cordobaman
$1500 plus shipping.
Please contact me to determine shipping rate from zip 16510.
Original factory boxes and packing.
I love these speakers. Upgrading to a higher model Spatial.
I am the original owner, and meticulous with the care of my audio equipment, smoke-free home.
Operate perfect. Physical condition is excellent, 9/10, they have been set up in the same spot since originally purchased and never moved.
Please examine the picture carefully, as they are part of the description of condition.
M4 Turbo S includes: Spatial M25 compression driver, film and foil capacitors, WBT terminals.
Type: Precision Point Source 2-way coaxial design, open-baffle, dynamic driver, controlled directivity, low noise design.
Chassis: Super HDF - 3 inch thick - low vibration structure.
Driver compliment: Two 12 inch mid/woofers, one wide bandwidth compression driver.
Crossover: 800Hz - Passive - Hologram Passive Network Technology.
Frequency Response: 45Hz - 20kHz +/- 3dB in-room response.
Sensitivity: 93dB - averaged across 200Hz to 5kHz at 1M - on axis.
Impedance: 4Ω nominal, 3 Ω minimum, low phase angle.
Dimensions: 36T x 14W x 3D inches, 44 lbs.
Made in USA.
Tom419
Where are you located?    Thanks
cordobaman
Erie, PA
